Question about Intel Motherboard
845gvsr motherboard dead
One 845 gvsr board ram slot got burnt. i repalced f7338 mosfet as it was faulty. Still it is giving rem beep. i changed ram even.where is the problem plz. tell me.
  • Rocky64 Mar 09, 2008
    Lost all sound on Intel P4 845GLLY motherboard and last time it happened problem was solved by downloading and reinstalling driver from Intel. This time NOTHING is making it work ! A run of Registry Smart reports ** problems, have deleted in device manager, have uninstalled, downloaded, reinstalled drivers, have run SFC, have replaced speakers, have run DXDIAG but did **t hear any test sounds. Audio is enabled in BIOS and all audi settings have been checked and rechecked for both volume level and muting. Have ** idea what to do/try next and was wondering if possible (and how) to test that the on board device is itself **t somehow damaged...but don't k**w how or why it should be. Any thoughts or other suggestions would be appreciated.
  • jaikumar Mar 16, 2008
    Thanks
    The solution was really helpfull.
    Regards
  • 152 Answers
Near by ram slot 10 ohm registance serial smd register check
some one register bank fail{beetween cpu and ram slot}
Posted on Mar 08, 2008
Have an intel 845 gvsr board. no beeps no display..
was you check your ram?/is your ram ok, usually the ram that half dead make this response, plug off ram then hear is there any beep, if yes change your ram if no its mean *********** board was damaged, change your motherboar
i hope this helpfull, please raet very helpfull or helpfull if you think this helpfull
thanks for using fixya
Jan 20, 2011 | Intel Desktop Board D845GLLY Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Intel 845 GVSR drivers for windows vista
Hello!
Your chipset drivers are available from intel here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065
Please select your operating system and hit "Go!"
Feb 17, 2009 | Computers & Internet
Error E9 on 845 gvsr
i have a 845gvsr mother board power not coming led is binking but not powered coming. what is the soution......
Jun 26, 2008 | Intel D845GVSR Motherboard
change to Windows XP,
windows vista will not support with *********** board
it will support more then 865 chipset
May 17, 2008 | Intel 845GE Motherboard
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
845gvsr motherboard problem
I think it is ram's malfunction. Plug out the ram chips. clean it's terminals with soft clean cloth.
Mar 26, 2008 | Intel Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
i don't know weathere you are awared of this or not...
to get the 32 bit graphic on 82845gv motherboard go to BIOS setting and change your video frame buffer size to 8 mb and agp aeperture to 256 mb and let the system boot... you will get 32 bit graphic with 1024 x 748 screen resolution... i have changed and believe me it is working
but only problem is that you will hardly play any game or use bubble screen saver..
Feb 24, 2008 | Intel D845GVSR Motherboard
Intel Motherboard Logo
198 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
