Question about Vacuums
Fixing my vacuum cleaner
I've had a Eureka Optima lightweight upright for 7 months. One day while vacuuming the carpet in the living room, the motor started making a grinding sound. I thought something was caught in the rollers. After cleaning the small amount of fibers from the rollers, the sound continued. I have no suction. What could have happened?
I have only two floors that are carpeted in my apartment.
I don't use the vacuum cleaning alot. Please send my some information that could save my vacuum cleaner.
  • Anonymous Mar 29, 2009
    Just stopped running. Brush still spins but no suction. Had a large visible clog that I removed. Even tried to "snake" it out with a wire hanger but there doesn't seem to be any clog left for it to latch onto. It does feel warm, though. Maybe just overheating because of the clog?
  • 30 Answers
Check to make sure that your agitator still spins. (Agitator = brush). If your agitator still spins, it eliminates your belt and agitator as likely culprits. The last possible solution would be that your vacuum is clogged. The grinding sound might be a motor-related issue or could possibly mean your bearings are going out. Check the bearings of the agitator and the motor of the vacuum.
Accessing to the agitator and belt can be done by removing the bottom cover of your vacuum. There are 2 scews that are holding the bottom cover to the head of the unit. Remove these 2 scews and the bottom cover should snap off.
Posted on Mar 07, 2008
How to replace the motor for the roller brush on the Eureka Optima upright lightweight 431
If you can hear the motor but the beater bar doesn't turn, it's the belt that needs replacing. If you don't hear a thing when it's plugged in and turned on, then you need a new vacuum. Besides, the part, if you could buy one, may cost half of what a new unit will cost. Treat yourself!
Cheers,
Chance
San Diego, CA
Oct 25, 2017 | Eureka Vacuums
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
Is there a diagram/picture to help me visualize how to put cleaner belt back in vacuum? I was taking base of vacuum apart so I could get rid of hair that were wrapped on the roller. The cleaner belt came...
Sorry to hear your belt fell out. Not good if you've never replaced a belt before...
Here is a website where you can read a detailed description of how to change a belt: http://www.ehow.com/how_8034505_eureka-belt-replacement-instructions.html
I don't think you'll need a photo, it's pretty straight forward. However, there are schematic diagrams for vacuums but they don't show how they go together.
If you have trouble, reply back to me and I'll try to describe for you.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 21, 2011 | Eureka 431A Optima Bagless Upright Vacuum
My Eureka Optima vacuum doesn't have any suction when on the floor option. How can I fix this?
It will as long as long as your accessory hose is properly inserted into the base. Otherwise the vacuum stays on the hose only.
Mar 13, 2010 | Eureka 431A Optima Bagless Upright Vacuum
No suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Oct 03, 2008 | Eureka 411A Upright Vacuum
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Go Ahead. Use Us.
Mar 19, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Lint from the carpet not being picked up, why?
Either the brush roll is not turning, or you have a clog at the inlet by the brush roll or in the hose.
Feb 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
286 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
