Question about Dryers
Cleaning out dryer
I would like to open up the dryer and clean it out
  • bolisa Apr 01, 2009
    I have lint building up behind the drum of my dryer, and I can see it through the holes in the back of my dryer, how do I get that out?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Okay. If the dryer is running well, there's no need to open the dryer to clean it. Clen aou the lint filer and wuth a special brush get any lint out of the area where the lint filter goes. Run a brush or vaccuum cleaner hose or your hand up the lint tubing and get all the accumulated lint out. Don't forget the vent leading outside.
If you MUST go into the dryer to clean it, check for a repair manual online or at an appliance store. ALWAYS unplug it from any power and if it's a gas dryer be carefull with the gas line. You may have a valve to temporarily shut off the gas flow. Turn it off in case you break the line when moving the dryer, if necessary.
Depending on the model dryer you have will determine how you get in. There are usually mounting screws on the bottom or bottom front (someone had to assemble it and if they can put it together you can take it apart) that hold the sheet metal "skin" on the frame. Once you 've removed the front and are inside, you'll see if the drum rides on rollers or just on a felt seal on the front. The tension of the belt may pull the drum down so be careful and watch out for sharp edges on that sheet metal.
This would also be a good time to check the belt for fraying. If it's an electric dryer there is a heat coil. Look for loose or heat-damaged wires.
Disconnect the vent tubing from the vent in back and using a brush designed for dryers, or a vaccuum cleaner, or your hand, pull any lint out of the dryer vent hose and the dryer itself. You might lube the rollers if it has any and check if the drum rides on supports or a felt seal that might be wearing down. And give the lint filter a good cleaning. Check it for holes, tears, and other damage.
Once all the lint is gone, and you find the spare change that dropped into the bottom, and maybe found that missing sock, you reverse the process. Put it all back together, making sure the drum spins freely by hand. Reattach the vent hose, and then plug it in, (turn on the gas if applicable), and before you shove it back into place give it a test run to make sure the motor turns the drum and the heat works.
Dryer maintenance once a year will keep it clean and running well.
On the other hand if it requires special tools, or if opening it up will void your warranty, call a qualified repair technician.
Posted on Mar 07, 2008
Why would a kenmore dryer get too hot?
Most likely cause would be that you need to clean the vent pipe.
Failure to clean the lint filter could also do the same thing. If the dryer vent pipe is clogged at some point the thermal fuse will open and the dryer hill no longer heat.
Lots of videos on youtube about cleaning dryer vents.
Aug 12, 2014 | Kenmore Dryers
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
Ler7646 jqo whirlpool dryer
broken door switch,if the dryer hasn't been cleaned out and you changed out the thermal fuse could be one of the t-stats on the heater box,the model number you sent doesn't come up,
Ler7646jqo,open the door,you'll see a tag with the model and serial numbers,on the frame around the door opening.you'll need an ohms meter to check the parts,you have to remove at least one wire going to the part you're checking with the machine unplugged and check the part for continuity,if the dryer hasn't been cleaned out most likely the high limit thermostat on the heater box.if you don't clean out the dryer and vent line it will pop again until the dryer is cleaned,the dryer is running to hot from the lint blocking the air movement and the fuse pops as a safety device so you don't have a fire.
Feb 19, 2013 | Whirlpool LER4634J Electric Dryer
Heater not heating up, keeps saying clean filter all filters r clean plse help,
you will need to disassemble the dryer and clean out all the lint, under the screen there is a sensor, here is a website that should assist in the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Nov 07, 2010 | Dryers
The dryer will not dry clothes and I have found condensate water under the dryer and in the vent hose. How do I take the dryer apart and clean out the lint?
Disconnect power first. There's a panel near the exhaust you can remove to clean out the bottom of the dryer. Two screws should be holding the top of the dryer down you can see when you open the door to the drum. Remove those and you should be able to fold the top of the dryer up to clean out the top of the dryer.
Oct 27, 2010 | GE DBSR453EBWW Electric Dryer
How do I remove/clean the filter on my Hotpoint Aqurius condenser drier?
There are 2 filters to clean on this dryer.
1 is at the bottom front left, pull all the way out, and wash clean under running water, quite in order to do this.
The second one is at bottom front right, again pull out to clean, but do not use water on this one.
Some dryers also have one located inside the door opening, pull out to clean if yours has one.
Please leave feedback.
Thanks
Nov 13, 2009 | Hotpoint TDC32 Electric Dryer
How do I open the dryer to get to the area around the tub
I hope this works for U
http://repair2000.com/dryer.html
Was this helpful?
May 13, 2009 | Maytag Dryers
How to i open a kenore dryer to clean it
is your lint screen on top or inside?mike
Feb 14, 2009 | Kenmore 65924 Electric Dryer
Lint alarm sounds after three to four minutes use
Open the back of your dryer and clean out all the dirt. Ours had an old rubber glove reducing the air flow which we removed. We closed the cover on the back of the dryer and have operated more than six months without incident. We lived with this problem for two years before we cleaned 'er up! Now, all is well with my soul.
Jan 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
How do i open Whirlpool Ultimate Care II dryer for lint cleaning? Do I open it from the front or back?
Hi thanks for the question. most dryers you can clean from the back . if its maytag ,its from the front. some whirlpool dryers its from the front. and clean all venting from back to the outside. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Dryers
Dryers Logo
218 people viewed this question
Top Dryers Experts
