Question about Intel Motherboard
GA-EP35C-DS3R random reboots
I have a new build that is randomly rebooting itself anywhere from every 2 - 60 seconds. I get the standard "good" post beep and then the system will reboot itself. Sometimes I have enough time to get into the CMOS and other times not.
The system specs are as follows:
Motherboard: Gigabyte GA-EP35C-DS3R
CPU: Intel Q6600 w/ G0 stepping
Memory: Corsair TWIN2X-4096-6400C5 kit (CM2X2048-6400C5-G matched pair)
HDD: 1x Samsung 250gb (SATA II)
2x WD 750gb (SATA II)
Video Card: MSI RX2600XT T2D512EZ (ATI)
Case: Microcenter PowerSpec
PSU: Cooler Master 600W
Any help would be greatly appreciated. Like I said, this is a brand new build and as such doesn't even have any operating system on it.
  • Buzznode Mar 10, 2008
    Thanks for the input Ben.
    I ended up getting another case & psu and building the system on the "bench" first, before sticking it in the case. However, while I was taking the system back apart, I did notice that the video card came out rather easily so I believe that it not being seated properly was the culprit.
    I knew better than to assemble the system without bench testing it first, but I was anxious to get my HTPC up and running, so I took a chance. :0)
  • 64 Answers
Hi Buzznode,
First things first - once you have all the components properly seated (sometimes if a RAM chip or CPU heatsink/fan isn't quite right it'll cause those problems) clear the CMOS entirely. There should be a jumper somewhere near the CMOS battery - move it from the 1-2 seating to the 2-3 (with the system powered down) and count to ten. Move it back over and then try booting up again. If the problem continues, swap the memory chips. Otherwise repost once you've tried the recommendation.
Posted on Mar 07, 2008
  • Ben Blissett Mar 13, 2008
    Hi Buzznode,
    Glad to hear it worked out. I'll assume it's taken care of - if not, just reply and I'll see if I can help further!
Alcatel Concorde ZTE keeps rebooting and then screen freeze
Dear Bruce.
Thank you for contacting Fixya. Try to hard reset your phone. It will lost all documents from your phone. Let me know need any guidline for hard reset.
Mar 31, 2014 | T-Mobile Sidekick® 3 Cellular Phone
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all...
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all styles) / Sidekick iD
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
on Dec 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dell PowerEdge 1500SC that started to reboot itself randomly but now switches off within a minute of startup
assume power supply is failing or overheating, suggest replace power supply for new one or one with higher power rating to cope with power demand.
I hope this was useful.
Oct 20, 2012 | Dell PowerEdge 1500SC...
Hughes sd-dvr-80 rebooting randomly now stays on powering up when
This is common with drive problems.
Could also be a power supply getting hot.
Apr 12, 2010 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Wbr-2310 wireless stops resonding randomly.
unplug for 10 seconds, plug back in. These units to tend to get a stat build up charge
Nov 08, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Fujitsu n6410 reboots randomly
format and install fresh os. keep good antivirus with good firewall. use avast professional.
Aug 29, 2009 | Fujitsu LifeBook N6410 Notebook
Constant reboots, replaced most parts
check the capacitors on the motherboard near the cpu and ram. They're the little round cylinders found all over the board. If the tops are bulging out or there is a brownish goo coming out of any of them, this is your problem. Normally the top will be perfectly flat, but if the capacitor has failed it will do what i mentioned above. Sometimes, if it hasn't failed completely, it will cause the motherboard to reboot randomly. I would definitely replace the motherboard if you find this and it should fix your problem. While you're at it, buy another motherboard and CPU and build yourself another entire computer because all those other parts you replaced are still probably good.
Mar 17, 2009 | ASUS P4P800S Motherboard
Intel Motherboard Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
