Question about Kyocera Mita KM-2530 Laser Printer
KM-2530 with C0050 error code ?
I need help !?
I have code C0050 on Kyocera-Mita KM-2530 with print-scan extention. Interfaces works in other copier so I tried to reset the copier memory and the copier freze ??? This code is not descript in the service manual.
If you have solution please.
Thanks!
  • Anonymous Oct 11, 2008
    Same Problem here with C0050 error.
  • Anonymous Mar 17, 2014
    I have been told to run the "dev simulation code" to stablize my copiers print, but I don't know the code or how to run it. Cany you help?
    Thanks Warwick
    warwick.stephens1@gmail.com
It's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
Posted on Jun 03, 2008
Km3035 black print problem in main board
Total equipment cleaning and replace the main charge wire
Dec 09, 2013 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM-2530 error close front coveR
The front door switch or actuator is broken or the door may be warped .Have you tried putting pressure on the front cover? as this may help to indicate if the switch is faulty.
Sep 10, 2012 | Kyocera Mita KM-2530 Laser Printer
Copier printing solid black kyocera 2530
replace the main charger the problem will be solved
Nov 03, 2011 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Try changing print driver and switch emulation to kpdl auto if not already there. If this doesn't work go to properties on driver under font and switch to bit map. Don't do this step unles yo have to it really slows down your printer.
May 29, 2009 | Kyocera Mita KM-2530 Laser Printer
Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
Apr 24, 2009 | Kyocera Office Equipment & Supplies
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Apr 23, 2009 | Kyocera Mita KM-2530 Laser Printer
Scanner problems after Mac Leopard Upgrade
check this link then make sure that you can send a 10 megabyte zip file to that folder from a regular pc with permissions and you can open it without corruption from the mac... if you cann't then you have network problems
Jan 06, 2009 | Kyocera Mita KM-2530 Laser Printer
Kyocera Mita KM-2530 Laser Printer Logo
1,336 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
