Try to reset the router. On the router you will find the reset button. press it and hold it down for 30 seconds. release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute and check if the power light stays solid.
If not then try to reset the router again.
check the IP address on the computer. If you are getting a valid IP address then try to open the set up page of the router.
If you are not getting the valid IP address and power light is not solid then I think you will need a new router.
Click here for more information about the router
SOURCE: dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
SOURCE: losing connection constantly
Is the power light on the BEFSR41 router flashing ?
If it is flashing then you will need to reset the router and reconfigure the router. If possible download the Firmware of the router and
open the set up page of the router , upgrade the firmware.
After upgrading the firmware reset and reconfigure the router. Reduce the MTU settings on the router to 1400.
Click Here for more info about how to open the set up page and other networking info.
SOURCE: Linksys WRT350N Connection Problem and Power Light Flashing.
Are you trying to set up the router ?
For this you don't need to use Linksys Easy link advisor.
Easy links advisor has bugs in it. If you call the Linksys tech support, they will also not help you for Easy link advisor.
All you need to do is, open the router set up page and check the settings of the router.
according to the settings on the router, you can connect the new device to the network.
is ther any computer connected to the router?
use that cmputer to open the router set up page.
SOURCE: Power light flashes constantly. LAN port number
i strongly suggest you go to live chat (CISCO), they will definitely help you set up your router equipment
http://homesupport.cisco.com/en-ca/wireless/lbc/WRT54G/download
let me know if this helps
please post positive repsonse feedback for me
The router is not booting at all, and the reset button has no effect. I am returning the unit to the shop for replacement/refund. It is very rare that a unit is faulty straight out of the box. Thanks anyway.
They replaced the router, and it fired up within seconds. Setup only took a few minutes. working fine.
