Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Ice forming on bottom of freezer
I recently noticed water near the freezer door and found ice had formed on the bottom of the freezer. After I had cleaned it out, the ice returned in a couple of days and it appears water may be leaking into the freezer from on of the vents. Any ideas what may be the problem?
  • 1 more comment
  • Anonymous Jul 11, 2008
    Similar type kenmore w/freezer on the bottom. Same exact problem.
    Any help appreciated!
  • nogobe Aug 15, 2008
    Same exact problem. Solution to the person with the initial problem did not work. No gap in seal. Water seems to be coming from freezer vent inside and continuously builds up the ice on the bottom of the freezer until the water does not have anywhere to go then starts to leak out/
  • Anonymous Mar 29, 2014
    ice forms in bottom of fridge thought a leak from ice maker turned water off still forming ice
    Problem Solver:
  • 12 Answers
Freezer drain is frozen over, defrost water has nowhere to go. Need to pull back wall in freezer and clear drain, put some towels down and pour hot water in the back pan until the drain is cleared.
Posted on Oct 05, 2008
    Problem Solver:
  • 15 Answers
Check for ice clogging the vents to the box from the freezer.. check and make sure the evaportator fan is working in the freezer compartment..check the timer and the defrost thermostat and heater..
Posted on Aug 18, 2008
    Scholar:
  • 160 Answers
Switch off the power
First keep all the items out
Open the door and remove all the fixers
let the whole body will be get dry
check the freezer is there any gap between the door
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 07, 2008
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
MAYTAG refrigerator
More then likely you have a clogged drain. This is a pain to get to, like most bottom freezer models. You will have to remove everything out of the freezer, remove the door and racks to access the rear freezer panel. Once you get there remove it. You will probably see solid ice forming below the evaporator coil. This is ice from the unit going into a defrost cycle like it should. That is not a problem. The problem is when the ice melts and turns to water it is suppose to drain threw a hole located right below the evaporator in the center. If you have a sheet of ice formed you will need to defrost it to get to the drain hole. You can use hot water. In the industry we de-ice the drain with hot water and then blow it out with a CO2 tank(compressed air tank). This is not my favorite job because it is messy and sometimes long. That ice does not melt fast. Any questions for me go to refrigerator repair and email me anytime.
Apr 09, 2013 | Maytag MFF2558VE Bottom Freezer French...
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
Ice in freezer bottom
2 things:-1)Freezer door does not close completely, leving a gap allowing outside air to come in and te humidity causes water to freeze at the bottom of the freezer. This would explainwhy is forming over 2 days.
2)If your fidge has a ice maker in the freezer and a cold water dispemser, the both these compartments water flow for the ice &for dispenser are controlled by a solenoid valve, which in turn uses a sensor to detect the quantity of water in the ice maker trays and switces off the wster supply appropriately. If the sensor in the icemaker fails to detect the right quantity, overflows very slowly so as to appear to be noticeable..............sdeep
Sep 03, 2009 | Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
