FixYa.com
Tags:
Monitors
Generic problem for all Monitors
Graphics card problems
posted by jflynn on Mar 07, 2008
I recently installed a NVIDIA GeForce FX5700LE 256MB graphics card into my dell dimension 550, I also installed a new psu to meet the power requirements. I did all this to make my new samsung sinc master 226EW work to its best. Now that I have everything like it should be my monitor will randomly go to black while I am working. It does this about two to three times a day and it stays black for about a minute. Is there anything I can do?
Comment by jflynn, posted on Mar 07, 2008
I have downloaded the latest issue. But thanks for the idea
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
PyroPCMan
Rank:Guru Guru
Rating: 91%, 188 votes
Good Day,
The first recomendation i can make is lowering the refresh rate of the monitor. This is done by going to start>settings>control panel>display. Click the settings tab then the advanced button, click the monitor tab and then set screen refresh rate to your lowest setting typlically 60hz. Let me know what happens.
http://pchelpforanyone.blogspot.com
Rating Locked! (?) jflynn has rated this solution as Helpful
Solution #2
Not Rated (0)
lucidreverie
Rank:Wiz Wiz
Rating: 85%, 35 votes
Hi Jflynn,
I'm not convinced that this is an issue with a driver, but I have to ask whether you've downloaded the latest drivers for the nVidia card.
If not, go here to download them and see if that helps.
Ben
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Pavilion F1703 17" LCD Monitor HP f2105 (Metallic, Carbonite) 21" LCD Monitor Philips 107E56 (Black) 17" CRT Monitor Philips 107E61 (White) 17" CRT Monitor Philips 107E66 (Black) 17" CRT Monitor Philips 180MT (Silver) 18.1" LCD Monitor HP 91 (White) 19" CRT Monitor
Can you Help with these Monitors problems?
Tatung - LD23HL Monitor
TATUNG LD23HL
trying to find a repair center... Answer This...
Toshiba 15 LCD Monitor
Monitor on laptop has vertical...
I have a toshiba satellite... Answer This...
Acer Monitor Lcd 22in X223w LCD Monitor
Computer slowing down?
Is it possible that an Acer... Answer This...
LG Flatron 775FT (White) 17" CRT Monitor
no signal
I have LG Flatron 775FT... Answer This...
Gateway FPD2275W (Black) LCD Monitor
Gateway FPD1975W TFT LCD...
Due to my involvement with... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
