How do i hook up my tascam fourtrack recorder to my computer
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there sexycat
first things first:
1) check the output you want to use on the tascam, then according, use de correct cable on the PC, usually RCA to mini pin connector, or RCA on sound card ( if appy)
other than this, check weather you can use the tascam with any aditional hardware for your PC. ( on manual)
Posted on Mar 14, 2008
Trying to connect peavey mixer to tascam 2488. I hooked the main to mic input. It will record but I can't hear the playback. through my pa system
Do not put mic switch it line input the mic has a preamp that will amplify microphone ss they have very low output, by using line the tascam will take a higher levl, why would you want to go mixer to mixer?
May 22, 2018 | Tascam Audio Players & Recorders
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
TASCAM DP-004 - SD card file access error
Stick the SD card inside your computer, if your computer does not have the hook up for it, Radio shack or Best buy can help you with that. Then you can save the files on your computer, then re-down load them back on your dp 004. But if your card is reading error then maybe you would have problems trying to move them your computer too. Bryan
Jul 05, 2009 | Tascam Audio Players & Recorders
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
How do i hook up my tascam 414 portastudio to my PC??
Assuming you want to keep your recordings at the highest possible quality, wouldn't it also work if you had an outboard component CD recorder? That way you retain the highest resolution at the first analog-digital step and once it's on CD you can rip to your heart's content or run it through the mixer again.
I have a Pioneer Elite PDR-509 that I have used for years. There are several 'professional' decks made by Tascam, Marantz, HHB and others that add the ability to use vanilla CDR's and CDR/W's instead of CDR-Audio and CDR-A-R/W media as mine uses and some can defeat the SCMS codes so you can do digital-digital multiple generation copies. Home audio CD Recorders will only digitally copy a first-generation digital original, unless the source was was made on a PC. Then it's always considered first-generation. The cost of the media isn't that much different these days. A standalone CD Recorder would also let you digitize those LP's and tapes you have hanging around or record Live through your mixer to CD. How about that!!!
There are plenty of them on eBay cheap and I'm still looking for the right one in case mine should ever decide to die. I see 7 pro models right now on eBay. I'd look for one that has Coaxial Digital inputs and outputs as well as Optical ones.
As for hooking up your Tascam, that would depend a lot on what sound processing software and soundcard you have - not my strong suit as I still do everything in the analog domain prior to cutting the CD and then ripping it to MP3 for portability and fast access. The physical hookup would be Line Out to Line In. After that it's all software.
Apr 30, 2009 | Tascam Starter Pack for 4-Track Cassette...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Software.
I don't believe any software comes with the DP-01.  After you record your tracks, you have to "export" them to your FAT drive.  Once they are on your FAT drive, you will be able to see them using Windows Explorer.  Your Tascam shows up as a removable disk.  Simply open the drive and you will see the available folders.  The WAV folder will contain your exported .WAV files and you can drag&drop from there.
If you don't have the manual, you can find it online.  It's free!
Oct 24, 2007 | Tascam DP01 All-In-One Recording Package...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
