GA-7VKMLS MOTHERBOARD It starts up but i get nothing on screen how do i reset cmos jumpers?
  • 33 Answers
You can do it one of two ways:
1. Remove the plug from your computer, then look for the CMOS batter is circular between the size of quarter and a nickel. Remove this and the plug for about 30 secs then put them both back in this should clear it.
2. Most motherboard has a cmos jumper that will clear the bios settings. Check your manual for the exact jumper and setting.
Posted on Mar 07, 2008
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Hi... i have gigabyte ga-945gcm-s2c and i dont know where is the jumper to bios clearing CMOS... please help me to fix this problem... thanks before....
You can get the manual here:
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_ga-945gcm-s2l%28s2c%29_e.pdf
But if you look to the right of the CMOS battery, you will see two pins, to reset the cmos, simply cap the pins with a jumper for 10 secs, or touch them with a screwdriver (mains power OFF of course)
Apr 19, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Forget GA-6VTXE-A bios password.
To Reset the BIOS Password, Remove the CMOS (Coin-cell) Battery from the motherboard for five minutes and restart the system. This will load the factory default settings and the password would be gone.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 22, 2010 | Gigabyte GA-6VTXE-A Motherboard
GA-G1975X OC FAILURE
reset the cmos either using the jumper if it has one or popping the battery out, then redo your bios on boot without overclocking to start then slowly adjust your fsb rebooting each time. if you remember the last setting before it crashed do not go that high. (remember to unplug the power cord before clearing the cmos)
Feb 21, 2010 | Gigabyte GA-G1975X Motherboard
Reset BIOS
In order to reset BIOS you need to remove the CMOS battery located on the motherboard and re insert again
Jun 20, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
No post start up
Only try to remove the cmos battery and reinsert again.......
Dec 10, 2008 | Gigabyte GA-K8VT800 Motherboard
BIOS problem
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
Aug 08, 2008 | Gigabyte GA-6WMM7 Motherboard
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Not starting
Hi ,
Have u tried?
First u clear the cmos means beside the battery there is one jumper with 3pins (2 pins are shorted with jumper)
U put the jumper in 2,3 position in system off mode keep some sec's time and kept the jumper as usaual.
Then u check the system ,if no display pl change the PSU
Pl try it
Was this soultion useful ?show ur appericiation by rating it
Apr 02, 2008 | Gigabyte GA-6WMMC7 Motherboard
Computers & Internet Logo
265 people viewed this question
Alun Cox
David Payne
David Payne
