Question about Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200N hangs on warmup
Xerox Phaser 8200 began warming up forever after heater lamp replacement. No fault codes, or messages.
Any assistance appreciated.
  • CSMorris Mar 07, 2008
    Lamps are illuminating properly and even turn completely off when temps exceed the set point. Diags state that all temps are within +/- 2 degrees of set points.
    Have reseated everything that is reseatable.
    No fault codes or messages are generated.
  • jsawyer Jan 07, 2009
    same issue.  says it's warming up... then after awhile restarts the warmup process all over again.
    Problem Solver:
  • 19 Answers
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Posted on Mar 14, 2008
    President:
  • 2,072 Answers
Did someone replace the entire heater or just the lamps?
It is important that the wattage of the lamps were 150 watts each, and that the ends of the contacts were cleaned well. Does it shut off during a run and warm up?
I have noticed with those assemblies that you have to clean the contacts well when replacing those.
If you are not faulting out, then they are working, but not at the level they should be.
The drum thermistor may also need to be replaced. That detects the temperature of the drum and would cause it to warm up slower then normal, but also, when those fail you normally get a fault code.
Just seems odd, though. It keeps running through my mind that the heaters are just not comming on to full brilliance, and that would mean for one reason or another, lack of proper wattage.
Could you somehow have gotten lamps or a heater rated at 220 volts and not 120 volts?
Posted on Mar 07, 2008
  • Rick Kasper Mar 07, 2008
    Well secondly, you could have a print head failing. The print head itself has to warm to keep the ink liquid. I am looking through information on that and came up with this.
    Problem:
    The Printer's Front Panel Hangs Displaying Warming Up-Please Wait
    Cause:
    The printer is having a thermal problem.
    2. Verify the printer is plugged directly into a known good wall outlet. Plug the power cord directly into a properly grounded electrical outlet. Do not use a ground adapter plug to connect the printer to an electrical outlet that does not have a ground connection terminal. Do not use an extension cord or power strip. Verify that the printer is plugged into an outlet that is capable of providing the correct voltage and power. 3. Test the printer disconnected from network/USB connections. 4. Reseat the printers RAM. 4. Reset the printer NVRAM.
    TROUBLESHOOTING TIPS AND HINTS:
    1. Before replacing parts, verify printer problem. Access and document fault codes, either from the normal mode or diagnostics. Use Section 3 of Service Manual to identify and troubleshoot fault codes. 2. Test printer thermal using diagnostics, Section 4 of Service Manual. 3. Replace parts only after diagnostic testing indicates a part has failed.
    PARTS:Parts are listed in the order of highest probability for repair.
    Printhead Assembly - PL 2.0 item 2
    Electronics Module - PL 5.0 item 5
    Drum Heater Relay Board - PL 5.0 item 17
  • Rick Kasper Mar 13, 2008
    You then have a bad electronics module. Not detecting the heat.
    And this was much more then a thanks for trying.
Xerox phaser 8200 fault code 15.004.45:30386
That is a drum heater fault code. The drum heaters are 2 ,,, 150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps. Let me know if you want me to send you info how to change them.
rak458@aol.com
Mar 09, 2010 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
PHASER 8200N ERROR CODE 15,004.45:7829
There are 2,,,, 150 watt halogen lamps in that machine that heat the drum. One or both have blown. How to be sure is, turn the lights off in the room of office the machine is in, turn the machine on, and look into the right side fan slots. After a minute or 2 you should see a glow inside the machine. ( You won't) those lamps are bad. Xerox will want to sell you a new drum heater for over $200,You can go anywhere that sells halogen lamps. Lowes, Home Depot or just about any place that carries lamps will have them. They are less than $15. I recommend , if you can find , the Sylvania lamps that are rated for 130 volts and are vibration protected.
If you want to try and replace them. let me know I will send you written instructions. Should take an hour or so to replace.
Mar 10, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error code 15.004.45:30201
The drum heaters are bad. There are 2 ,,,, 150 watt halogen lamps that warm the drum. One or both of them are bad.
If you want the directions let me know.
Feb 19, 2009 | Xerox Phaser 8200 Laser Printer
Printer not working
That is a drum warm up fault. There are 2, 150 watt halogen lamps in the drum heater that blow.
If you want to replace them let me know, I will sent you the directions. I can pretty much say 100 percent that is the problem.
Feb 16, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 phaser dp
The drum heaters are out. They are 2, 150 watt halogen lamps that go bad.
That is exactly your problem. I can tell you how to replace them. Not real difficult, takes an hour to an hour and a half.
Nov 24, 2008 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8200 Won't warmup properly
Does it diaplay a fault code? It may take 20-30 minutes to display. I suspect if you leave it on long enough it will come up with a 15,004.xxx code.
I suspect you have bad drum heaters, but please leave it on for an extended period of time and see what fault code comes up.
Thanks.
Sep 30, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
654 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
