Question about Garmin StreetPilot c340 GPS Receiver
Unit fails to maintain charge
Unit will not re-charge from the cig.lighter. I changed the fuse and still the same results. Could it be that the battery needs to be replaced? If this is the potential solution, will I be able to change the depleted battery myself.
  • 405 Answers
You are correct, most GPS units use a lithium ion rechargable battery, typically they loose there ability to retain a charge after about a year or so depending on use, resulting in the unit having to be always plugged in.
You probably could replace the battery on your own if you could get one, (needs to be soldered into the mainboard) however GARMIN does not sell battery's to consumers, they state that a battery can only be replaced by a garmin service tech.
Check the link below for contact info for garmin.
https://buy.garmin.com/shop/shop.do?pID=290&tab=sp340
Hope this helps
http://pchelpforanyone.blogspot.com
Posted on Mar 07, 2008
Why does CIG lighter fuse m6 keep blowing?
The CIG lighter has failed and needs to be replaced.
Jan 01, 2016 | Cars & Trucks
Interior heating fans/ blowers not working
You have a blown fuse, check them all including the under hood or trunk fuse center.
Nov 08, 2013 | 2003 Renault Megane
Hi,i'm having trouble with the cig lighter on my car, it keeps blowing fuses. can i wire it directly to the battery with an inline fuse? How would i do this?
you could do this by running 2 wires directly from the battery to the back of the cig lighter and by fusing the positive.if it is only when using the cig lighter and not when charging a phone ect.it could be element on the cig lighter shorting
Apr 05, 2010 | 2000 Volkswagen Golf
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Nov 05, 2009 | 2001 Ford Focus
My garmin does not operate plugged in to my car nor by battery
You have not said why that is....
Have you fully charged the battery prior to using in the car?
Using the power from the 12v plug in a vehicle will not "charge" the internal battery, but tends to maintain it somewhat. If the fuse in the end of the 12v connector plug is blown and the battery in the unit is low then this will cause the unit to shut down or fail to fire up.
Please check both, the units battery level and the fuse in the cig lighter plug and the plug that connects the unit to the cig lighter outlet.
Now the second half of your statement:
Nor by my battery
It is either not charged ( AC charger) or it has reached the end of its life which if used correctly is about 2 years. If the life of battery is shortened , then it is by a common practice of misuse. This misuse is to have the unit plugged to the car 12v when staring the engine.
1) it damages the battery life
2) It can and does damage the SIIRF chip, which is responsible for connecting to the satellites
I suggest that if it does not charge over a 10 hours Max period to its full state, then replace the battery immediately to avoid damage to the electronics from battery leak.
Thanks for using FIXYA
Oct 29, 2009 | Garmin nuvi 205W GPS Receiver
My tomtom one will not charge
most car chargers are fused at the tip Try changing the fuse in the DC charge unit
Jul 19, 2009 | Tomtom GO GPS Receiver
I have no audio from my stereo
If you're not an electrician or a certified Hyundai Technician, find one. Let them diagnose the problem you described.
May 07, 2009 | 2004 Hyundai XG350
No power to cigarette lighters
Two years later and you solved my dead cigarette lighter. manual says fuse 35--but it did not say to check 38 on the left fuse box. Thanks--blown fuse and everything works. Thanks
Dec 20, 2008 | 2007 Volkswagen Passat Sedan
Utility cigrette lighter in dashboard
you may have burned out the lighter unit.check the wires for melting also!
Sep 23, 2008 | 2004 Toyota Camry
Battery charging
Cig-lighter offers 1A current. The battrey will be fully charged for 4 hours if the unit is not used.
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
