Oil pump bad,oil pump strainer stopped up,rod,and main bearings worn out,cost,just depends on the actual problem. Oil pump bad,oil pump strainer stopped up,rod,and main bearings worn out,cost,just depends on the actual problem.
You can't post conmments that contain an email address.
The harmonic balancer is basically a counterweight attached to the front of the engines crankshaft. The balancer has a rubber cushion that could fail although I would suspect that would be a very rare occurrence.
I think it would be worth it, to get a second opinion on this diagnosis.
Not unless you plan on doing lots of modifications. The computers are different and the transmissions are different. It can be done like with all things cost is the factor.
has to engine mounts on most of them however some have additional ones called wish bones running on the top of the engine. They all run under fifty each
take loose the motor mount bolt and jack the front of the engine up to clear the oil pump and remove the pan,.the bolt the runs thru the center of the mounts ,the easiest way ,hope this helps you, thanks robert b.
Before starting this job I would get a repair manual. This is not a easy job, 6+ hours for an experienced tech with all of the right tools. And you may have to discharge and recharge the AC system.
