Question about Zanussi ZWF1630 Front Load Washer
Washing machine displays E30
When switched on, the display shows E30. When a wash cycle is started, the machine goes straight to 'drain'. Even with regular draining / emptying filter cartridge it still does not work. Please can you help.
  • taibsuk Oct 12, 2008
    when i turn my zanussi on to start the program it beeps and goes straight to E30 error.  PLz help.
  • 157 Answers
Heater
Posted on Oct 05, 2011
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Sparks
Posted on Apr 09, 2008
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Wont start, goes straight to cycle ended
have the program board check for failure
Jan 04, 2016 | Electrolux Washing Machines
The door is opening even when the machine is on.Error code 50 comes on display
It ispossible that the error comes because the door was opened during the cycle. Remove power for sometime to reset . Now check the door lock and safety on feature while the cycle starts. If there is fault in this link the program will show an error.
Check the lock : http://www.espares.co.uk/advice/washing-machines/a/7/1207/how-to-replace-a-washing-machine-tumble-dryer.html
Jun 28, 2012 | Washing Machines
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a hotpoint top load that will not fill.It goes straight to wash cycle. And on the spin cycle it drains only;no spin
This is caused by a bad pressure switch. With it being bad, the machine thinks the tub is filled with water therefore it starts washing rather than filling first.
Please rate solution.
Sep 05, 2009 | Washing Machines
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
486 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
