Question about Fusion FEW12PK Car Subwoofer
High pitched noise comin out the sub
I got a fusion 1600watt amp and a 1000watt 12inch fli sub . the sub is makin a high pitched noise , i ve try another sub on it and it does the same ,have any1 n e ideas email me please @ ginga_fudgie23@yahoo.co.uk
  • gingafudgie Mar 08, 2008
    i got the ground lead about half a foot long and its bolted 2 the lock of the boot but i ll clean it up and let u know but if its not that what is it??
    Sergeant:
  • 300 Answers
You may have a ground loop issue. Make sure your ground lead is as short as possible (<1ft, if possible) and that it is mounted to a nice, clean (unpainted) spot on the vehicle. If you have multiple amps, try and ground them to the same point.
Posted on Mar 07, 2008
Audi 500e radiator fan makin a high pitch annoying noise,hw do I fix it?
Sounds like a bearing in the electric fan is bad, replace fan motor
Mar 16, 2015 | Audi Cars & Trucks
Bridge two 12inch subs together
it depends. what is the ohm rating of each sub, and the amp. are the subs DVC(dual voice coil)? and are you trying to bridge them directly to the amp? i need more info, but i can say that if they are 4ohm subs, if you run them parallel, they will become 2 ohm. to keep them at 4 ohms, they need to be run i n series, and you need more than 2 for that.
Oct 07, 2009 | Car Audio & Video
Only one thump when car is turned on. problem in amp strength or subwoofer?
try pluging in a diff, speaker to the amp see if u get sound.try powering the sub with a home radio just to see if u get sound at all if ur getting sound from the sub then its the amp but u could of damaged it when the amp over heated
May 03, 2009 | Kicker SoloX S10X2 Car Subwoofer
2 1000watt 12inch
tolally bad wiring on you spk if you say series parell chek the way the spk is wired in the box it could be wrong
Apr 26, 2009 | Performance Teknique ICBM-892 Car Audio...
Rockford sub squeaks
Hello markwasicki,
You did not specify what type of enclosure the subs are in or if they share the same airspace. But the sound you describe sounds suspiciously like the enclosure is at fault and not the sub itself.
Remove and reverse the subs in the box and test for the noise again. If the noise is still produced on the same side of the box, it's the enclosure. If the noise follows the sub, then you have a problem with that sub.
If the box is making the noise, and it's a ported box, you probably have "port noise". If it's a sealed enclosure, you could have either an air leak or flexing noise. In either case, repair the enclosure or put the subs in a new one. If the sub itself is making the noise, there probably isn't much you can do. Most likely some part of the voice coil assembly is touching where it should not.
Hope this helps.
Apr 18, 2009 | Rockford Fosgate (P212D4) Car Subwoofer
Can the sony xplod 1000watt amp be bridged for more power to just one sub? also what problem would cause a subwoofer to make a slight burp noise whenever the car is shut off or into the non accessory...
This amplifier can only be bridged for a single subwoofer with an output rating of 380 watts bridged. The amp is not rated for 1000 watts.
The burping noise you here is the electronic switch discharging power off on the large capacitor that are used in high performance amplifiers. Regards, rcampsr
Feb 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
12 inch subs emit engine noise
You will have to go buy noise filters for the headunit. This will stop engine noise
Jan 31, 2009 | Precision Camera Precision Audio 12-inch...
High Pitch Noise Coming Out Of My Subs?
sounds like it could be a warning sound that indicates either a short or a bad connection and is tripping the safety warning. check all speaker terminal connections and connections on the amp to make sure there is nothing loose or touching
Jan 27, 2009 | Fusion FEW12PK Car Subwoofer
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
High pitched noise comin from sub
if sound also goes away when throttle is released and sound returns when throttle is pressed down, then you have engine noise from car engine electronics. In older cars, this was quite noticeable when the cars had distributor caps. The electrical noise caused by arcing required for the spark plugs could be your issue. It is resolved with a noise filter which gets wired inline leading to your in-dash deck and power amp (if you have one). The filter can be found many places including Radio Shack and Crutchfield.com. First find your total wattage draw for each component of the sound system (deck and amplifier), then divide by 12 to get current draw through filter. Purchase that size filter or larger.
Feb 12, 2008 | JBL GT1041 Car Subwoofer
Fusion FEW12PK Car Subwoofer Logo
100 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
