Question about Cameras
Samsung digimax i5 camera
Exposure to excessive unable reset this on the menu have same prolem
when the memory card has been removed D53 Digimax Samsung. Over exposted on all outside pics. tried reset on all functions, Auto,M,Scene,etc. works inside not outside pics. Removed batts, installed new, flash works OK.
  • shorty_kay20 May 08, 2008
    I have the exact same problem, The camera will take photos inside but will not take photos outside. The outside photo turns out white. Ive tried changing the exposure setting but nothing makes a difference. I called a repair shop they said its the shutter and it will cost $100. The other thing thats happening is when conecting to the computer the computer says there are no photos to upload (there are 40 photographs in the camers)
    Please Help
My memory card is "locked" , on my Samsung Digimax i5 and I cannot use it! I do not know how to fix this, any help??!!!
Posted on May 06, 2008
My samsung digimax i5 screen is broken , can i get a new screen for it for being refixed?
Posted on Apr 22, 2008
How do i unlock my memory card on the samsung digimax d53?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 14, 2010 | Samsung Digimax D53 Digital Camera
My samsung digimax d53 camera can only hold six pictures and one video but the memory says 16mb what do i do?
16 MB memory is not a great deal. Check to see if your memory card is being used rather than built in memory on your camera settings.
Jul 03, 2010 | Samsung Digimax D53 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it but it says check sd card. I tried another 1GB memory card and it worked. I know that the problem is with my...
Unfortunately, you can't. The D53 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware issue, it is not something that can be changed with a firmware update. You need to use cards 2GB and smaller.
May 14, 2010 | Samsung Digimax D53 Digital Camera
Can i move pictures from internal memory to an SD card??? samsung digimax D53
im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
May 01, 2009 | Samsung Digimax D53 Digital Camera
Lost leads for samsung digimax d53
You may use a memory card reader if you want to download your pictures from your memory card to your computer.
Jan 02, 2009 | Samsung Digimax D53 Digital Camera
Wanted to increase memory on my Samsung digimax d53
It sound like your card is a larger capacity than your camera can handle. On a quick 'net search I found 2 GB cards are sold as add-ons for this camera, so they should be OK. A 4 GB card might work, but it would be cheaper anyway to just get 2 X 2GB cards.
tgvern
Dec 22, 2008 | Samsung Digimax D53 Digital Camera
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung digimax i5
menu tab.
Samsung i5 camera
Try the following and see if this helps:
menu tab.
Aug 12, 2008 | Samsung Digimax i5 Digital Camera
Card locked
Remove the memory card out of your camera. On the left side of the card is a white switch. Move it to the upright position. Resinstall card back into your camera.
Jul 06, 2008 | Samsung Digimax D53 Digital Camera
Cameras Logo
225 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
