Question about Sony RDR-GX355
Command codes I accidentally switched my command code from dvd3 to dvd1 and now i am locked out of the player completely. it just keeps flashing dvd1 on the screen and thats it. How do I fix this?
  • 8 more comments
  • joepoll Mar 08, 2008
    I tried what the manual says but I was unsuccessful. The problem is with the remote i think. No matter what I press on the remote, I get the dvd1 on the recorder but I have no control of the player. I also have lost access to the system menu by doing this. please help. The manual also says that if the recorder is switched to dvd1 or dvd2 then you will lose control of the player. Which I have. What do I do?
    Thanks. I'll give it a try.
    Thank you sir. I was misunderstanding what the manual says. 3 kids and a wife is what I blame it on. Thanks for saving me from filing it under "G". Thats garbage to all you people not from PA.
  • Anonymous May 26, 2008
    locked out its in dvd1 instead of dvd 3
  • Anonymous Aug 04, 2008
    do I fix this?
  • rio9760 Aug 04, 2008
    do I fix this?
  • specialnotes Aug 10, 2008
    Same problem my brother currently has w/ the Sony RDRGX 355. He tried what the manual says but has bee was unsuccessful. The problem is with the remote menu. No matter what he presses on the remote, he's getting the dvd1 on the recorder but he has no control of the player. He also lost access to the system menu by doing this. The manual also says that if the recorder is switched to dvd1 or dvd2 then you will lose control of the player, which he has. Is there anyway of resetting it? The manuel seems to be no good to solve this dilema
  • lanetamer Aug 23, 2008
    The website mentioned in the solution,http://129.33.22.12/release/, is no longer functioning. Does anyone have a replacement or equivalent site to visit for these instructions?
  • andyshirsch Sep 18, 2008
    I see the dialog, but have not found the solution.  Where are the comments on how to fix this problem?  It has just happened to me and I can't figure this out.  Also, the pdf is not opening up.
  • Anonymous Feb 27, 2009
    can not get out dvd1
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Posted on Oct 09, 2008
  • lcalogera Oct 09, 2008
    Sony's Toll Free Tech Support # Is 1-800-488-7669
    New Friend:
  • 4 Answers
Remote dvd1
Posted on Feb 05, 2014
I was able to fix the problem by using my sony universal remote which allowed me to go into the set-up mode and switch dvd1 back to dvd3 and everything works fine now. I turned off the dvd player first so that the setup would not read the dvd i had in the player. When you power on the player, hit set up on your universal remote and then find out what buttons on your remote will allow you to go through the menu until you can make the change. I hope it works, it worked for me and now i'll never play around with that function again
Posted on Oct 01, 2008
My kid lost my remote completely and I have not been able to use anything but the buttons on the face...
Looking for some codes to program another remote.
Don't think it's gong to turn up since he likes to throw stuff in the trash can.
CR
Posted on Jul 08, 2008
  • 492 Answers
Go to this web page and check page 23 for instructions on setting the remotes command mode, you will want to set it to 1. http://129.33.22.12/release/RDRGX355.pdf
Posted on Mar 07, 2008
  • Sean Johnson
    Sean Johnson Mar 08, 2008
    Once again you have to switch the remote to the command mode that the player is on. What I send you was information on changing the remotes settings not the dvd player.
  • Sean Johnson
    Your most certainly welcome, sometimes family can add to non solution because of the amount we care for them.
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
Command codes
Try to reset the player :You can also try a hard reset: Unplug unit from AC mains and remove all cables from unit. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the unit and see if it works..if this fails then you need Restart the recorder Press down power switch for more than 10 seconds until Sony DVD appears this will set to default factory setting in the player.....
Sep 22, 2008 | Sony RDR-GX355
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-GX355 Logo
730 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
