Hotpoint First Edition FEW10P Front Load Washer Logo
Anonymous Posted on Mar 09, 2010
By djkeen279 on Sep 28, 2009 " " We have an intermittent problem with the door locked light. At certain points in the cycle the light flashes and the cycle stops. If we push the panel around the light or the door it will eventually stop flashing and the cycle will continue. It's now happening more often. I'd just like to know if this is a common problem and if so is there an easy fix? I'm thinking that it is either the door lock or the printed circuit board.
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
12355
Points
154
Its probably the module, the door lock is connected to the board, try checking the innerlock first. with a reader
Oven door remains locked after self clean cycle - but the oven has cooled
Number one Tip, NEVER use self cleaning cycles. They only exist to break ovens and sell parts.
Try disconnecting the mains after about 10 minutes of cool down time. If that doesn't work, you will need a service call to correctly diagnose if the lock solenoid has failed or you need a new control board.
Why You Should (Almost) Never Use Your Oven's Self ...
https://www.thekitchn.com > why-you-should-almost-n...
Sep 8, 2022 - Self-cleaning, often with temperatures that go over 1000°, is a particular problem. The elements and the oven just get so hot - much, ...
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) ...
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to ...
How Self-Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Jan 31, 2023 • GE Ovens
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Why do doors lock and unlock while in motion?
2009 LTZ/Cycling (on/off) Door Locks - Chevy Malibu Forum ...
www.chevymalibuforum.com/forums/showthread.php?t=6599
10 posts - ‎8 authors
02-17-2011, 07:26 AM ... Two or three times while driving( in motion) the door lockswill cycle two or three times through the lock/unlock positions and then will stop. ...Since i can't produce this glitch on demand there is no point taking it to the dealer. ...The Malibu system will not let you lock the doors when the door is open.
Door Lock Actuator Recall? - Page 4 - Chevy Malibu Forum ...
www.chevymalibuforum.com/forums/showthread.php?t=7950&page...
Sep 23, 2011 - 10 posts - ‎7 authors
When I was driving this afternoon, the car would unlock itself at random intervals. ... It is reasonable to expect that Chevy could design a car whose doors remain locked while the car is in motion. ... 2009 Malibu 2LT, Adopted 5-7-2011 ... If you can get them to replace ALL 4 of them for a $100 deductible, I'd ...
[PDF]2011 Chevrolet Malibu Owner Manual
https://www.chevrolet.com/.../Chevrolet/.../2011_chevrolet_malib... ChevroletChevrolet Malibu Owner Manual - 2011 ..... remotely lock and unlock the doors from up ... The trunk can only be opened when ...... the vehicle is in motion can be.
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Central locking cycling intermitantly when driving
There is probably an intermittent short in the switch that unlocks the doors. Maybe something go spilled on the button that unlocks the doors. The doors automatically lock after the car reaches a certain speed, but the unlock button may unlock them when you go over a bump or lean on the area around the switch.
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
