Question about Kodak EasyShare C633 Digital Camera
My camera won't connect to my computer
This just recently happened. when i connect the usb to my camera the usb doesn't read my camera. it is connected properly but no pictures pop up or anything.
  • 477 Answers
This can be caused by several things. First plug up another USB device to that port. if it works you know your port is good. next hook up the camera and look in my computer for a extra drive letter. if you see on that is your camera. If nothing still see if you can hook it up to another persons computer to see if your cable and camera is ok. If the camera does work and none of these help out then it is a drivers issue. you will need to go into saft mode by hitting f8 when the pc first starts up goto option 3 safe mode now right click on my computer Icon and goto properties. Find device manager. in their click on hardware now find the USD devices and try to remove all of the usb listings once you have done that reboot the system the system will come up in normal mode. And start loading all of your usb devices again. Now hook up the camera and see if it works. If that does not work then in XP goto the system tools are in you accessories area. and choose system restore. choose the date closest to the last time it worked. Once you restore the system then hook up the camera again. This should work as long as all hardware is good.
Posted on Mar 24, 2008
Most recent pics won't upload- you can see them on the camera screen but won't upload
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 22, 2012 | Nikon D60 Digital Camera
My laptop has a windows 7 OS 32bits and it doesn't read my kodak easyshare c813
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Aug 12, 2011 | Kodak Easyshare C813 Digital Camera
Cant connect to my pc anymore via USB, its reads communication error when i turn it on? what can i do to fix this problem? i have tried another cable but same thing happens.Mind you the camera has never...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 21, 2011 | Canon PowerShot A550 Digital Camera
Computer isn't recognizing my Samsung PL120- Instructions have read that if you connect the camera via USB the program should automatically install. It doesn't. If i look under removable devices...
Use a card reader. Since your computer has a USB port, you can get a card reader that reads SDHC cards. This is exactly how I do it on my computer.
Jul 07, 2011 | Samsung PL120 Digital Camera
Whenever I plugged my webcam in, I have to wiggle the wire around a lot and if I touch it when its working, it stops. Now though, It won't work at all. Can I fix this?
It sounds like your USB terminal on your computer is bent or damaged.
This often happens.
Try using another USB port as there are usually multiple ports on the computer.
If this still doesn't work, the camera's cord may be what's having the issues as the terminals and contact points inside are bent.
I would consider getting a new webcam or replacing it if you have recently purchased it.
Hope this helped!
Thanks!
Jun 13, 2011 | Cameras
On my FinePix s3100, cannot transfer picture from camera to computer. After setting the Usb Mode setting in the Setup menu, it reverts to picture read screen. Recent problem - all other settings are fine....
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 31, 2011 | Fuji FinePix S3100 Digital Camera
I get an USB error when I connect my t1031 to my computer... happens everytime? My pc does not recognize the camera... this just started happening recently and it happens on every computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 03, 2011 | Polaroid t1031 Digital Camera
I can't download pictures to My Pictures
Aug 01, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Computer won't recognize my camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 07, 2009 | Olympus FE-210 Digital Camera
Kodak EasyShare  C633 Digital Camera Logo
3,334 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
