Question about Samsung 510N 15" Flat Panel LCD Monitor
Have a Synkmaster 510n with problem
When I connect the monitor to ac outlet, it shous the flying color square warning that the monitor cable is not connect. As soon as I connect the cable, the flying worning disapears and the monitor goes black. Can it be fixec???
Thank you,
Pedro
  • Dabundo Mar 11, 2008
    Nope, that is the proble. As soon as I connect the monitor cable the screen goes black. I've tryed several PCs with same results. Could it be the monitor board? Can I purchase it, what will be the cost???.
    Cheers,
    Pedro
  • Dabundo Mar 18, 2008
    I don't have an answer to my problem. Should I throw my monitors to the garbage can?
  • 3 Answers
Hi folks! i have experience same prob. after plugging the monitor, gets black screen ryt away? heres a first try, remove the crystal component at the circuit board of that lcd monitor, change it with same value. just refer to the schematic dagram of samsung 510n. just download the diagram. try n see..f it work, then success!!! pls. post after, tnx
Posted on Feb 27, 2010
    Champion:
  • 220 Answers
Confirm this is a monitor problem by connecting toanother working Pc.Also try starting in safe mode and see if you get stable image.If in safe mode you get image your image settings may need to be readjusted.
Samir
Posted on Mar 10, 2008
ACER P223W Monitor Ghosting (Multi-Mon Setup Win8)
Hummmm.... are both monitors connected to the same surge protector?
I had a similar problem with 2 monitors and a Brother Laser Printer (with a long USB cable), where the Brother was connected to a different AC outlet connecting to a different breaker! No fair...
That happened because that 'Brother' outlet was part of a new room addition... and hence a 'new/different' circuit breaker.
Once I connected the Brother to the same surge protector my video problems went away. And yes, the "grounds" are connected properly at both outlets... go figure.
Anthony
Nov 22, 2017 | Acer P223W 22 inch Monitor
How many cables to hook up monitor to tower
1 Single VGA cable will connect into the back of your PC. Another power cable will be needed to plug the monitor into an AC outlet.
Mar 14, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
I have a SyncMaster 510N, where i find flickering problem. But display is okay. I difficult to view the screen. Is this major issue?
power cable and data cable connection may be loose
tight it
2. your wall socket of power may not having earth connection properly
Sep 08, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
No display
I would advice you check all the connection on the monitor to ensure all the cables are properly attached to the monitor and the central processing unit, if still no display, you can change the cable to try another cable to see if it will give difference, if nothing happens, you might need to diagnose the monitor to see if it powers on, if it does and no display, you will need to replace the picture board on the monitor to solve the problem.
Take care,
Jul 09, 2010 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Feb 22, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung SyncMaster 510N LCD TFT Monitor
Samir
Jun 13, 2008 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung SyncMaster 510N 15 not optimum mode
There is an issue with the microcontroller with 510N LCD monitors. Get it repaired at samsung service center.
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Samsung 510N 15" Flat Panel LCD Monitor Logo
124 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
