Question about Microwave Ovens
Problem with Frigidaire CPLMV168CC1 Over the range microwave
There is no sound when I push any of the buttons on the keypad and the exhaust fan cuts in and out but not all the time.
Any suggustions?
Thank.
  • kac654 Mar 09, 2008
    Thanks for your suggestions.
    I tried the hard reset and its still the same. I already have a copy of the owner's manual, thanks anyway.
    Is there a way to determine if the problem is with the keypad or the control board?
  • Microwave Ovens Master
  • 9,098 Answers
I would suggest a hard reset - unplugging it for a few minutes then trying again.
If you don't have the owner's manual, you can download it here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316137207en.pdf
If it doesn't have an option to turn sounds on and off, you may have a problem with the keypad or control board.
Moisture may have gotten into the controls from steam (from not using the exhaust fan while cooking on the stove top) or spray cleaner (from spraying the keypad directly instead of spraying it on a soft cloth).
Please reply back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 07, 2008
  • William Miller
    William Miller Mar 10, 2008
    If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:http://tinyurl.com/yzjozk
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here:http://tinyurl.com/gv383
    I'm not sure if yours would have it, but some have a helpful "mini-manual" hidden behind the control panel. It will help in testing.
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
Frigidaire gallery otr microwave vent not working
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
Apr 04, 2013 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Problem for Frigidaire PLMV169DC Stainless Steel 1000 Watts Microwave: The built in exhaust fan has never worked properly from day one. It barely can hold a napkin when placed under the screen filter....
if the exhaust is not vented out side the house and there is no window slightly open to allow air flow.then yes this is normal.if it is vented to the outside this is not normall.i hope this is some help
Jan 22, 2010 | Frigidaire PLMV169DC Microwave Oven
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Fan Button doesn't work
HI, in most cases, the button will be fine. there is an error code that will illuminate on the control if the touch pad starts to malfunction(sticking buttons). this is more likely an issue that concerns the integrity of the fan motor. have it tested. replace it if found to be defective.
Jul 21, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
109 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
