Question about Refrigerators
Hi, I HAVE A OLD 1950s frigidaire fridge and it works really well, trouble is at the bottom where the motor is there is a very bad smell like rotting cabbage, so I have cleaned the motor area out but it still smells bad. can anyone help. Regards Brian.
    Sergeant:
  • 288 Answers
There should be a condensate pan under there somewhere. Usually the smell like yours is from the water and some food sitting there. Is this fridge out in a garage or somewhere like that? I have pulled animal carcasses, especially reptiles, out of the coil area. They crawl up to get warm. Hope not.
Posted on Mar 07, 2008
Frigidaire troubleshooting
i have a frigidaire gallery that has a strange smell too it all the way through it. It really smells
Jan 04, 2014 | Washing Machines
Ice is forming in bottom left hand corner of fridge to the left of the drainage hole. Also have a bad smell in fridge even after thoroughly being cleaned
Hi Margaret, It is most likely that the bonding between the drain tube and liner has detiorated and moisture has infiltrated the foam insulation, And it freezes in that corner because the transfer pipe between Freezer and fridge evaporators is located there! which will be at about (- 26 degrees celcius) thus freezing the moisture in the insulation, this could also account for the smell... No cost effective repair unfortunately.
Dec 13, 2013 | Frigidaire Refrigerators
Brand new fridge. I have a bad smell like urine comming out from the bottom front. is this a leak.. fridge is staying cold. this smell started a week ago. Fridge is 2 months old
smell is urea,it is a gas produced when plastics get hot,it will go away in time,but also check the drain for a blockage (syringe with clorine bleach)and if fitted, wipe out the condensate pan with clorine
last make sure the door seals fit all round as iif not flush any condensate will drip out from the front bottom.
Aug 12, 2010 | Frigidaire Refrigerators
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Nov 17, 2009 | Refrigerators
My fridge smells terrible and I've clean out
You got some thing in the insulation...its done
Aug 19, 2009 | Frigidaire Refrigerators
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
A really bad smell coming from the fridge
I had a similar problem with an unbearable smell, not inside, but outside the refregeration compartment. it was from the defrosted liquid that gets stored in a small open tank at the bottom on the rear side of the fridge. over time , particles settle along with water and gives a rooten smell, cleaning this tank solved it.
Hope this helps,
Feb 10, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
I have a homeking fridge freezer and there is a really bad smell coming from the fridge which is not because of food. i have emptied the fridge and thoroughly cleaned the fridge but the smell is still...
Hi, i have the same problem with my Homeking fridge. Because it is a frost free firdge, there is a little resevoir at the back, with a small little tube leading from the base of the fridge into it. There are 2 screws holding it in place. Unscrew these but keep the resevoir firmly in place as the nasty parmesan-type smell is actually stagnant water and you really really dont want to spill it. Empty it and then what i did was bleach and anitbacterialise the resevoir tray and the little tube thing. Though I had the problem solved but now it is doing it again less than 2 months after this, so I'm going to contact the people who sold it to me. This is how you get rid of the smell though!!
Good luck
Laura
Aug 14, 2008 | Refrigerators
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
