Question about Intel D850MV Motherboard
Want to change priorities of boot in BIOS
Have tried entering on boot, Delete, F1, F2, F12. None of these gets me into BIOS
  • 405 Answers
This link is for the owners manual on that board,
http://download.intel.com/support/motherboards/desktop/d850mv/sb/mdmvenglish.pdf
On page 47 it states F2 is used to get into the bios, press repeatedly while booting so you don't miss the window, and of course check you keyboard, it should flash the caps,num, and scroll lock lights on boot.
Hope this helps
http://pchelpforanyone.blogspot.com
Posted on Mar 07, 2008
F2,f8,f10,f12 don't work to get bios menu . how can i change my bios setting during set windows up by usb.
if you are trying to get into your BIOS you have to press which ever key when you are booting the system you can't be in windows because it wont get the proper key stroke to enter the BIOS.
Mar 19, 2015 | Computers & Internet
How do i access the boot menu on a Vizio All in one PC Model CA24-A0. Im trying to do a clean install of windows 7.
press f7 key ,select usb storage from start up menu and press enter ,follow steps,hope this helps :)
Oct 15, 2014 | Vizio All-In-One CA24-A0 - Core i3 3110M...
I am unable to open bios. Actually I wanted to change the boot sequence for HARDDISK TO CDROM but could not open bios. What to do?
Hi ranjanaghosa,
I see that you need to change the Boot Sequence on you Thinkcentre M55e but could not get in BIOS right.
to be able to change Boot sequence you can also try on tapping f12 as soon as you power the machine ON untill you get the Boot Menu you can also change boot sequence from there.
To get in the BIOS on a desktop you need to keep on tapping F1 as soon as you power the computer ON, but if still this does not work you can try Tapping on the Delete key to get in the BIOS, getting in the BIOS depends on the motherboard some use f1 to get in the BIOS some use Delete to get in the BIOS on desktops.
but using the F12 key can be done as well if the F1 or Delete key does not work.
I hope that this helps.
Have a nica day,
mvincentc
Jun 03, 2011 | Lenovo ThinkCentre M55e 9637 Desktop
Having problem with operating system disc....can get to advanced bios menu but do not know what to change the priority of.... first 2 items on the menu won't let me change priority value and the 3rd...
there should be a boot menu command at start up just like you entered the system bios, i believe the e machine boot command is F12 that will give you the opportunity to boot from what ever you want on that boot only. so in your case of course you would scroll down to cd and hit enter. press any key to boot hit any key and boot.
May 30, 2011 | E-Machines eMachines Desktop PC
How can i change boot sequence of my desktop
You have to change the boot order at the bios settings. Just after the screen comes up, before windows start up press (repeatly) the F2 key (depending on the model, maybe F1 or del key) and go to the boot sequence. Here change the boot order as you wish.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 15, 2011 | IBM Lenovo ThinkCentre M55e PC Desktop
PXE-E61: media test failure/PXE-M0F: Exiting PXE ROM/Operating system not found. This message is coming up on my screen. The only thing I can access is F2
Hi, welcome to FixYa.
Apparently, the error of your system is missing operating system, this could caused by many things, from broken hard disk to missing boot record such as MBR.
First, try to fix your BIOS start up setting. Depend on your BIOS setting, go to your BIOS by pressing F1 or F2 (apparently this is your key) or END during boot time. Then go to Boot Setting (this name is vary in any BIOS manufacture, so try to locate the similar name). Change the boot priority with first priority is your hard drive,
If you still don't able to boot, this can be caused by missing boot record such as MBR. This is little bit trickier. The fastest way (I assume you use Windows), is to insert your Windows installation CD/DVD then boot from there (by changing boot priority again from BIOS, or some new BIOS support pressing F12 to choose boot device). After you boot from there, repair your Windows.
I hope this information will be helpful. Thank you for using FixYa!
Mar 07, 2011 | Acer Aspire 3680 Laptop
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
Jan 31, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
How to set boot priority in bios is thinkcentre lenovo it has no option in bios
when i am enter in the lenovo bios in bios option have four option for first boot device. which i am select.
Oct 21, 2009 | Lenovo ThinkCentre® M55-8810 PC Desktop
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
Willn't boot up frome the cd rom
You can do this by changing the BOOT Priority in your BIOS settings.
To get into BIOS:-
When you first turn the system on, you get what they call a POST screen (normally has the laptop logo or enegy star monitor rating), at the bottom of the screen, it should give you an option or two (i.e. F1-Boot Options, F2-Setup (also called BIOS). Different systems use different keys to enter the BIOS (or SETUP), this is usually F2 or Delete.
Once you are in the BIOS, just have a browse for BOOT OPTIONS or BOOT PRIORITY, and change the value of FIRST BOOT to CD-ROM.
Save these new settings to CMOS and exit. The system will now reboot, and this should solve the problem
Nov 28, 2008 | Computers & Internet
Intel D850MV Motherboard Logo
75 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
