Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Picture will not take when flash is on
The camera works fine when the flash is turned off. It will not take a picture when the flash is on in automatic or manual. What should I do?
  • 1 more comment
  • lizel Mar 08, 2008
    Thanks for trying. I have two new batteries, neither make a difference.
  • pafmartwo Mar 31, 2008
    I have the same problem. I bought a new battery, charged it up, and then tried it in my camera. Still no flash
  • thaineseguy Apr 18, 2008
    I have the same problem and it's not the battery. I also tried replacing the flash circuitry with the replacement Canon sent me but that didn't help either. Any more ideas on what we could try?
  • Canon Master
  • 4,738 Answers
How old is the battery? The symptoms you're describing sound like a worn down battery. If it's the original battery that came with the camera, it may be time to consider a new battery. One way to check the battery's health is to apply a voltmeter to it, and compare its voltage with that printed on its casing. Replacement generic NB-3L batteries are going for about $7 on Amazon or ebay.
Posted on Mar 07, 2008
Why when taking a picture is the background of the picture flashing
If the image you see in the camera display flashes then it's an over/under exposure warning feature that's turned on in your camera. It's there to tell you when an area of your picture is either too dark or too bright. You can usually find a setting in the camera's menu that allows you to turn it off. Look for "Exposure Warning" in your menus or something similar.
Oct 14, 2014 | Cameras
The viewer of my canon A620 is blank when I turn on the camera to take a picture
Press the DICP button 2 - 3 time and see the LCD turning on or not. Let me know.
Aug 07, 2012 | Canon PowerShot A620 Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Canon ds6041 digital rebel problem with AF 70-33 mm
Try cleaning the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
May 31, 2010 | Canon Digital Rebel / EOS-300D Digital...
Wont take a picture unless I turn off the flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
Turning off after taking a picture with a flash
Sorry but that is just because the flash is recharging.. It turns the screen off so it can charge the flash faster.. No worries it works fine :)
Jan 24, 2008 | Nikon Coolpix 4600 Digital Camera
Will not take picture
This has happened with 2 of our Stylus 410s. It has to do with the flash not working. If you turn off the flash, the picture will take. I am trying to figure out how to fix the flash portion myself...=)
Sep 27, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
