Question about Cameras
Metz 45CL-4 not firing consistently... Hi, Have a problem with a Metz 45CL-4 flashgun. I may have damaged the circuit by rapid charging from an external NiMh pack whilst trying to form the main capacitor. Have done this previously, with this and other Metz 45s and it's always been OK. I normally get a full charge in about 2.5 seconds only now I have a problem firing the flash. Have reverted to testing with 6 good alkaline AA batteries (reading 9.06v on pack) but problem persists. Symptoms: - Looks like flash charges OK and holds charge, but won't discharge on command. Green 'ready' LED is on. Triggering by test button or sync lead makes red LED come on then fade down. Initial test button press results in one very rapid fade of red LED, subsequent test button trippings slow red LED to a fade in about 1.5 seconds. I can hear a faint electronic 'click' when using the test button but flash fails to fire most of time. Very occasionally the flash will fire so it could be a trigger circuit problem. If I press test button repeatedly I can get a flash once in about every 15-40 attempts to trigger, typically taking about 20-30 seconds! I haven't yet measured the output but subjectively it looks about correct for the head mode setting. I think main cap is OK because I can get an occasional flash, heard an initial whine on first charge and green 'ready' LED is on. No subsequent whine until new attempt again on following day, when some of charge may have dissipated or if I eventually trigger a full discharge. All LEDS on head work OK as head dial is switched between modes or power settings. Are you familiar with this problem? Is it fairly easy to fix? Is this a DIY fix (it looks quite complex inside? I know to be careful with/discharge main cap) or will it need professional repair? I opened casing, nothing looks or smells burnt out. Apart from not firing gun is in excellent, unmarked condition. Would appreciate any advice. Thanks. Ricky
  • dmhphoto Sep 04, 2008
    Exactly the problem I have with the 45-CL1!
    I used NIMHs (various brands, from 1200 mAh to 1450 mAh) for about a year. never mixed brands in the battery holder (45-39). Worked great for a long time. Must have put a full set of batteries through it every day for a year! Now it whines just fine, ready light illuminates, ready light blinks out when triggered (by cord-test button) but flash fires only occassionally. It seems that a fresh charge or some fresh Alkaline cells help to make the flashes more frequent, but not for long.
Hi Guys!
I have had the same problem on CT-1 s and CT-5s.
In both cases the flash cable (called PC synch cable) was to blame. If flash fires correctly with the test button on the handle, then cleaning the cable contacts with contact cleaner spray seems to be the best first step.
Regards,
Gerard
Posted on Apr 29, 2009
Can a Metz 45CL 5 be used with a CanonD40 safely?
Are you sure that you have a 45CL-5? It's a model which I've never seen nor heard of before, but it's possible that it is a non-standard custom model number for a specific supplier or territory.
The answer to your question is "possibly": but you asked if it can be used safely so the answer must be a firm "no".
Various sources (e.g. here) quote the trigger voltage on the (presumably closely related 45CL-4) to be a little higher or even vastly higher than Canon's 6v limit. Metz themselves are unclear on the issue and it doesn't help that they do not list the CL-5 on their support page nor on their main corporate page, but they do list a 45CL-4 and a 45CL-4 Digital. The differences between the two models may just be to add additional capabilities which suit digital SLR's but perhaps it also brings the trigger voltage below Canon's 6v limit.
As there is so little published information about the 45CL-5 then I strongly suggest that you do not risk your camera until you have a definitive answer from Metz themselves: you can contact their support service by clicking here. The link is for the UK, if you're elsewhere (Australia?) then you may need to make your own search.
I hope that I've been of some assistance and that the links provided help you to get the answer straight from the horse's mouth. Please take a moment to rate my answer.
Feb 20, 2010 | Metz 45 CL-1 Flash
Hi My Metz 45cl-4 asa control on the hammerhead
yes it can be repaired use a WD 40 spray on asa dial try it
Oct 10, 2009 | Metz 45 CL-4 TTL Flash
Metz 45 CL Flash to use with Nikon D90
Metz in Germany advises Models CT45-1 with Serial No's 53400 or less have High Voltage triggers and must not be used on NIKON Digital Cameras Models D70 ,D80, D90 etc.and will damage Flash and even Cameras. according to a email received today. 21/09/2009 Models CT45-4 and 45CL -4 ore ok.
Michael T
Mar 20, 2009 | Metz 45 CL-1 Flash
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
Metz 45cl
I found th answer in the manuel. You can not use flash when pluged into charger.
Apr 24, 2008 | Metz 45 CL-1 Flash
Cameras Logo
162 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
