SOURCE: How to fix a Miele
Below is how error codes are deciphered by the cycle lights and water level light. This should help diagnose the failure. I recommend to have service technician diagnose and repair your washer.
LONG DRAIN error code will cause the NORMAL, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
If the drain time exceeds 6 minutes, the wash cycle will stop. Push the START/OFF button to reset the mode, a drain task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
INCORRECT FILL WATER LEVEL error code will cause the HEAVY DUTY, PERM PRESS, and HANDWASH cycle led lights to come on and the WATER LEVEL light to blink.
Wash cycle stops. Press START/OFF button to enter Standby mode. Execute a Diagnostic Test to drain the water.
POTENTIAL CAUSES:
UNEXPECTED FILL DURING AGITATION OR SOAK error code will cause the HEAVY DUTY, NORMAL, and the HANDWASH cycle lights to to come on and the WATER LEVEL light to blink.
The pressure switch contact selected has opened during agitation task. The wash cycle stops and a Drain task is executed. Once the Drain is complete, the cycle stops.
Push the START/OFF button to reset the operation mode, a Fill task is executed and the previously selected cycle resumes.
POTENTIAL CAUSES:
SLOW FILL error code will cause the HEAVY DUTY,NORMAL, and PERM PRESS cycle lights to come on and the WATER LEVEL light to blink.
If the Fill task exceeds 20 minutes, the wash cycle stops. Push the START/OFF button to reset the operation mode, a Fill task is executed according to previous Wash Temp selection and the previously selected cycle resumes.
POTENTIAL CAUSES:
Hope that helps..........
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Wet clothes in washer, which stopped during the night. Red "Intake" light is on.
Hi. My drain light is flashing and the door is locked? What do I do?
where is the drain pump
