Question about Intel D850MV Motherboard
Enter BIOS on boot
I have D850MV motherboard with Intel P4 and Have tried Delete, F1, F2, & F12 on booting to enter BIOS, all without sucess. How do I get into BIOS to change booting to CD or DVD drive?
I am trying to stay legal. The version of Windows XP Pro presently on this computer is on a newer computer. I want to load a older version of Windows XP Pro, which I own, on this computer. It will not load and tells me that the version on this computer is a newer version.
  • yelmerc Mar 10, 2008
    Thanks for confirming that f2 was the correct key. I subquently found that it wasn't working because of the keyboard (Microsoft office keyboard). I really like this Keyboard and when I loaded Vista and found that it wouldn't recognise it, I got rid of Vista. I feel that Microsoft selling a Keyboard then coming out with an operating system that doesn't recognise it is dirty. Then not supporting the keyboard is rotten practice.
    Thank you again for your response.
    Problem Solver:
  • 18 Answers
According to the intel manual the key is F2
"The BIOS Setup program can be used to view and change the BIOS settings for the computer. The
BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST)
memory test begins and before the operating system boot begins."
That is from the manual for the board, instead of reinstalling Windows you may as well just change the product key on one of the installations to your other copy.
Posted on Mar 07, 2008
I am unable to open bios. Actually I wanted to change the boot sequence for HARDDISK TO CDROM but could not open bios. What to do?
Hi ranjanaghosa,
I see that you need to change the Boot Sequence on you Thinkcentre M55e but could not get in BIOS right.
to be able to change Boot sequence you can also try on tapping f12 as soon as you power the machine ON untill you get the Boot Menu you can also change boot sequence from there.
To get in the BIOS on a desktop you need to keep on tapping F1 as soon as you power the computer ON, but if still this does not work you can try Tapping on the Delete key to get in the BIOS, getting in the BIOS depends on the motherboard some use f1 to get in the BIOS some use Delete to get in the BIOS on desktops.
but using the F12 key can be done as well if the F1 or Delete key does not work.
I hope that this helps.
Have a nica day,
mvincentc
Jun 03, 2011 | Lenovo ThinkCentre M55e 9637 Desktop
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
Jan 31, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
When i turn on my PC, I get a black screen with "BIOS Rom Checksum Error" on it - Windows will not boot up - I can't get it to boot up - what's wrong?
it only means that you need to update your bios these updating the bios with the correct version will solve your problem
Nov 22, 2009 | Intel D850MV Motherboard
Trying to boot fm CD/RW drive. Can't get at CMOS/BIOS to change boot process. Motherboard is Intel D875PBZLK -875p. F12 at bootup doesn't bring it up, nor does, F2, escape, delete. Using Windows XP SP3.
The command key is F2 - start pressing it immediately after you pressed the case start button and don't release it until the bios is loaded. If it doesn't work then probably your keyboard is iffy, try with another one.
Oct 24, 2009 | Intel D875PBZLK (D875PBZLKPRESCOTT)...
Which key to press at startup to gain access to BIOS E2180 Intel
There are a number of keys used to access the system BIOS at startup. F2 is probably the most common, but I see you've already tried that. I've also seen the ESC and DEL keys used, so try those. If that doesn't work, start working your way across the F1-F12 keys.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Boot from cd
when u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
Nov 30, 2008 | Intel Motherboard
Failure to go to setup or display boot devices
Try changing Motherboard battery it is probably flat
Oct 23, 2008 | Intel D865GLCLK Motherboard
Unable to boot from USB fey on D850MV Motherboard
Download updated bios here
follow instructions carefully to update bios
use the F8 key right after power up to select boot device.
May 09, 2008 | Intel D850MV Motherboard
Want to change priorities of boot in BIOS
This link is for the owners manual on that board,
http://download.intel.com/support/motherboards/desktop/d850mv/sb/mdmvenglish.pdf
On page 47 it states F2 is used to get into the bios, press repeatedly while booting so you don't miss the window, and of course check you keyboard, it should flash the caps,num, and scroll lock lights on boot.
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Intel D850MV Motherboard
Intel D850MV Motherboard Logo
196 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
