Question about Electrolux Central Vacuum
Electrolux central vac problems
Lack of power and not picking up when hand nozzle is used. When it is turned on the kickplate comes on. The central vac is less than a year old and the canister is not full and the filter is clean.
  • 1 more comment
  • Anonymous Sep 21, 2008
    My problem is that the hand tool works but the vacuum canister doesn't.
  • Anonymous Mar 17, 2014
    My Central Vac unit will not turn on. The first time, flipping the breaker switch worked. Next time, pushing the reset button worked. Now, nothing works to turn it on.
  • Anonymous Mar 30, 2014
    it is not picking up
  • 4 Answers
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Posted on Nov 18, 2008
  • 55 Answers
Do you get suction when hose is removed, but no suction when hose is on? If yes, you have clogged hose.
Posted on Mar 07, 2008
Electrolux central vac system with service lit in screen. What needs serviced?
Check the motor compartment to clean out dust if needed, motor brushes, relay and filters. It's a good idea to service your power nozzle once a year too.
Mar 24, 2018 | Electrolux Vacuums
Lack of suction at power unit
Check that the Handle has a slider to adjust air flow, Electrolux Vac's arent really designed for carpet cleaning, check hose for breaks or cuts and everything is secure, while its on run your hands all over the hose and vac to locate any air flow that should not be.
Let me know.
Nov 15, 2007 | Electrolux Centralux Vacuum
I have an older model Electrolux central vac. When I put the hose into the wall outlet, the cannister comes on but there is no suction ? What is needed to correct this?
Three things are the most likely.
1. Since it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. It will probably need to unclogged at an authorized Aerus Electrolux store.
3. A dirty filter. This is probably the first thing to check for, since it's so easy. If it's dirty, it needs to be thoroughly rinsed under warm water. Then allowed to thoroughly air dry prior to use. For this reason, it's highly recommended that an ECV owner have an extra filter on hand.
Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Central Vacuum
What do I do when there is no suction. My central vac just stopped picking up and though I emptied the machine and replaced the filter there continues to be no suction.
1. If it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. Please don't try to take it apart to remove the clog. If you can't get it out, take it to a reputable vacuum repair shop and let them.
best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked
3. Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Pu3650 Central System Vacuum
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
http://www.aerushome.com/storelocator/
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
When I disconnect the power nozzle on my central vac I have no power for the accessory items
If there's power to the power nozzle, there's power going to the powered accessories, as well. The problem must be due to a defective/broken "item". It could be a loose wire, a switch, or the accessory motor. It needs to be replaced, or taken in to an authorized shop for repair.
Aug 14, 2010 | Electrolux Central Vacuum
Central vac... picked up rings, how do we get them back
Bummer! The rings are still there. They will either be lodged in the pick up nozzle or in the bag itself. Take the bag out, this will be am out door job due to the dust present. Open the bag and carefully search through the debris. They will be there. Don't throw that bag away until you find them.
Zashiban
Jun 23, 2010 | Electrolux Harmony Canister Vacuum -...
How replace lightbulb on carpet beater (Electrolux central vac). Can't find any screws near light
To replace the bulb you will have to remove the power nozzle cover. Remove the cover by extracting the screws from the bottom. Take notice of which screw comes from which hole. Depending on the year, one screw may be shorter than the others. If put back in the wrong place, the screw will come through the cover when replaced. Once the cover is removed it's easy to replace the bulb. Make sure everything is lined up when reassembling.
Dec 30, 2009 | Electrolux Centralux Vacuum
Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
Mar 18, 2009 | Electrolux Centralux Vacuum
Vacuums Logo
274 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
