Question about Microsoft Xbox 360 Console
Power it takes me at least 3 times of turn my 360 on and off before anything appears on the screen and once in a while the 3 red lights show but i just turn it off then back on and it goes away. help wats going on is that normal.
  • 123 Answers
3 red lights is usually an overheating problem.
go to http://support.xbox.com and register your details.
MS should replace the unit for you.
x-b-m
Posted on Mar 07, 2008
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
3 red lights
Use the towel trick. Go to goole and type in xbox 360 towel trick!
RATE MY ANRWER!!!!
Nov 24, 2008 | Microsoft Xbox 360 Console
Xbox 360 red ring
first of all, 3 red lights USUALLY means that you have an internal hardware error. microsoft has a garuntee that if your xbox DOES get the 3 red rings, you can send it in to them and get you xbox fixed or a totally brand new one for FREE. but before you do that, you should check ALL of the cords to make sure that they are plugged in right. there is a reported 33% of the Xbox 360 that were produced have a serious problem- once the motherboard reaches a certain temperature is bends, causing some solder balls to lose contact with the GPU and motherboard.
If there is anything that you want to be sure of before you take apart your XBOX 360 is assurance that what ever your going to do to it, is going to work!
just go to this website:
http://top3redlightfixes.com/XBOX3RedLights/xbox_360_3_red_lights.php?gclid=CIeBnJi1pJYCFQgRFQod0lsd7A
my friend used this site and got his xbox fixed in no time and he learned some suff too.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
Xbox 360
Try using your xbox 360 console without your hardrive. If the problem continues, the tree red lights means general hardware failure. Microsoft covers those with an extended warranty and you can have it repaired for free.
Apr 18, 2008 | Microsoft Xbox 360 Console
Display Issue
It is headed for the 3 red lights. Just a matter of time before the GPU solder looses contact.
Jan 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
21 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
