Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson cx5400 changed cartrides and only puts out blank pages. Ihave tried every thing as far as nozzle checks and head cleaning etc.
  • Anonymous Jun 05, 2008
    Stylus CX5400 runs page through the printer, but page comes out totally blank although ink cartridges are new
    Thks for rescue
    Chris
  • Epson Master
  • 691 Answers
This sounds like a common problem that affects many CX models. You can find a countermeasure for this issue HERE. This should get you up and running again.
The fix requires some dis-assembly of the printer.
(http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical)
Posted on Jun 03, 2008
My epson cx5500 does not print (test print ) I've been through a nozzle check and have fresh cartridges.... just end up with a blank page
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaced.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new inkjet printer.
Jan 17, 2011 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My printer epson 5400 wont print my word document
Try to use the copy function to isolate the issue, if it is from the unit or from the computer. If copy is blank, run a nozzle check ( Press the left Menu button on the control panel until you see Nozzle Check, then Press the Color Copy button.) to see if all inks are shooting out. If nozzle check pattern is not good, do head cleanings ( Press the left Menu button until you see Head Cleaning on the LCD screen.Press the Color Copy button ).
I have an Epson stylus CX5400 all in one printer. It does not print, when I send a document to print the pages are blank, I have put in new cartridges
Do a nozzle check sounds like your nozzles need to be cleaned!! Here is a link to Epson http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25301&prodoid=36478881&category=Products
Aug 27, 2009 | Office Equipment & Supplies
Still getting blank pages.
You have air or dry ink in the nozzle chambers, you use the head cleaning facility but when it finishes it asks you to print a nozzle check pattern, click the finish button.
You need to do 4 head cleans and cancel the nozzle check print after each until the 4 are done then allow it to print the pattern.
This will prime your heads and clear out any air locks.
The only other thing I need to check, but it's a bit of a numpty suggestion. If you have not removed the yellow 'tear off' strips, no ink will flow and your chambers will be full of air. If this is what happened, remove the 'tear off' strips and carry out the procedure above.
I hope this helps.
You don't need the utility for this but it would be handy for you to have.
It is quite easy to find, it's on our home page and on the Epson page just below the big blue drop down menu box. It's simply a 'click here' link along side the text "If your printer needs resetting" etc etc.
Nige
The INK Store
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Jun 17, 2008 | Epson Stylus C60 InkJet Printer
Won't print(after changing cartridges
blank pages and bad print are not the same problem. Regarding costly ink, a epson printer tech told me once that the secrete to cleaning a bad print head was to run deep clean 7 times in a row and then a head test and it has worked for me several times on other printers (not an expert here, just personal experience).
Additional note, I have seen both cleaning chemicals and cleaning cartridges on the web, example, searching google for one for my printer I would search for cc-bci-6c which is for a canon cyan cleaning cartridge. Don't know if they work but in case it helps.. good luck.
Barry,
Mar 02, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
