Question about Sony PlayStation Portable (PSP) Console
Psp my psp refuses to startup games, the UMD refuses to load,what could the problem be??
  • jon2008 Mar 08, 2008
    my psp will not read disk when game is in.
  • Anonymous Mar 08, 2008
    i have the same problem.any solutions?
Try updating the firmware ...
Posted on Mar 08, 2008
My PSP refuses to load games of any kind and will not load any other application while the game is in the PSP, but will work without any game in it and I have the newest update.
Must be a dysfunction of the UMD reader. Did you have the same issue with the previous firmware?
If not, try to 'downgrade' your psp to a previous firmware (can't be done with every firmware, make a quick search on google and you should find out if you can)
If the issue still occurs then its definately the UMD reader.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
My psp isnt playing a brand new game. it wont load the umd. the umd is pretty clean. i wait for it to load and it wont.
Below where the UMD game appears on screen try the button below that should say 'Update PSP'. The game could have an update for the PSP and won't play without it. If this doesn't work contact Sony Website Forums and see if anybody there has had the problem.
Oct 31, 2010 | Sony PlayStation Portable (PSP) Console
Psp won't load umd games
The UMD drive is bad, you can either look around for a replacement drive if you know how to take apart your PSP to replace the drive or just get a new PSP.
Aug 08, 2009 | Sony PlayStation Portable (PSP) Console
Cannot load umd games
If you have custom firmware, make sure your "execute boot.bin" and "plain modules" are both disabled under your advanced configuration settings of the recovery menu. Also, make sure your ISO/CSO games are saved in the ISO Folder of your memory stick and that your UMD MODE is set to NO UMD REQUIRED. Your PBP Games should be saved in your PSP/GAME Folder.
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
Psp always read from umd,making it hang
Hi! I incounter this problem as well even without UMD its still loading and even I disable auto-start UMD still same so I tried reflashing the software but still same problem so I discover the solution before you turn-on your PSP try to open your UMD cover you'll see it will load faster then close again the cover once you see the battery and clock icon... The problem that causing this is the switch inside the UMD possible its stock-up or spoiled already!
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
The psp umd does not get read
my psp is not support memory stick
Mar 14, 2009 | Sony PSP (Piano Black)
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Psp
Usually when the psp starts loading up it will make a loading up noise if you don't hear this its because your UMD driver is malfunctioning
Sep 28, 2008 | Sony PlayStation Portable (PSP) Console
Psp-lazer ain't reading the games
This link should help.
  • Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
  • Try playing the UMD on a different PSP system. If the UMD plays, the original PSP system may be the problem. If the UMD does not play, the problem may be isolated to the UMD itself.
  • Try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
Nov 10, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
