Question about Vacuums
My vacuum does not have any suction, and it spits out dirt when I roll it backwards. It is an upright Hoover Elite
  • dcroda Mar 10, 2008
    Your comment completely helped! My vacuum is fixed. Thank you so much!
  • 30 Answers
Trouble Shooting guide:
1. Check to make sure that your agitator still spins. (Agitator = brush). If your agitator does not spin, it could very well be a belt gone bad and means there will be no suction.
2. If belt is fine and agitator spin, your vacuum could be clogged. A clogged vacuum can be cleaned with a brush inserted into the hose of the vacuum to pull out the debris.
Posted on Mar 07, 2008
I have suction through the hose but not when using in the upright position. The problem started once I removed the filter to clean it.
there is a chance that the hose between the ground pick-up and the suction hose is clogged,, this happens when the filter is blocked and all the dirt and stuff only makes it part way up the hose and then settles at the bottom. run a wire coat hanger down the line to break up the blockage.
Dec 30, 2010 | Hoover U5507900 Elite Rewind Bagless...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Apr 16, 2010 | Vacuums
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
I have the Hoover upright windtunnel and have used it only once. It worked wonderfully the first time but now only the hand tool has suction. I can't find the book that came with it though. How do I get...
Seems like you must have suction at th hose. The either a belt came off or it is plugged up at the dirt inlet by the brush roll. Some Hoovers have a spring loaded door that opens and closes depending on whether the handle is down or in its upright position, It may not be opening when you drop the handle to vacuum.
Jun 08, 2008 | Hoover Vacuums
Loss of suction in my Hoover Windtunnel bagless selfpropelled upright
Did you check the dirt inlet by the brush roll, filters ok, they should be replaced once a year. Belts can look fine, but if they are a few months old, I am sure they have stretched and the brush roll will not turn like it should under load. It is possible that the motor isn't running up to speed, thereby reducing suction.
Mar 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Wind Tunnel Upright Self-Propelled
Thanks to reddevil6. Sure enough it was the belt. What I did was take off the belt and flipped it over, worked like a charm. Since it was stretched on one side the other side was still ok. Still need a new, but s aved me a trip to the store!
Nov 21, 2007 | Vacuums
Vacuums Logo
268 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
