I cannot go to the website, we tried to optimize the browser, IP address is correct, we are able to get reply to modem and website but i cannot go on line
    Brigadier General:
  • 3,614 Answers
you are the one who was ordered on a chat?
Posted on Mar 07, 2008
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
Dell pc wont pick up internet
There are wide issues that may occur, with a issue with "dell pc wont pick up internet" is very general, so please be specific, however i went over most issue step by step, hope this help
Make sure you have the correct IP scheme for your network. This would include the:
IP Address
Subnet Mask
Default Gateway
DNS Servers
Click on start, run, type in cmd, The run IPCONFIG /ALL. A sample where a router is used is in the following graphic.
IP Address:
If you have a router, common examples would be:
192.168.0.x, 192.168.1.x or 10.0.0.x
If you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
What you don't want to have is something like 169.254.x.x. This means you are not getting and IP address assigned and needs to be resolved first.
Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0
DNS Servers:
Make sure you have the correct DNS Servers.
Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
Sometimes (as in this example), it is the actual DNS servers used by the ISP.
Possible causes for not getting an IP address assigned are:
1. Defective cable, network card or port on the router. Make sure you are using all known working components.
2. Your router is not configured for DHCP (which would automatically be assigning IP addresses).
This and can be done from that same command prompt you used to run IPCONFIG
2. Try pinging the router's IP address
e.g. ping 192.168.1.1
If you get a reply, then your connection to the router is working.
If you don't get a reply, then you need to double check your network card, cable, port on the router. You might also see if any other computers on the network can do the same.
3. Try pinging an external site by IP address
e.g. ping 4.2.2.1
If you get a reply, then you have a connection to the Internet.
If you don't get a reply, there are several things you can try:
1. Double check that the router is connecting to the Internet. Typically you can access the router through your web browser and check it's status.
2. Take the power off your DSL/Cable modem and Router. Plug the modem back in a wait a minute or so. Plug the router back in and wait a minute or so. Then restart your computer.
3. WINSOCK Fix - It is possible that the WINSOCK Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Name
e.g. ping www.yahoo.com
If you get a reply, then you have a connection to the Internet and DNS is working
1. Double check your DNS entries
2. You many need to use the same DNS IP address that your ISP or Router is using.
3. On rare occasions your ISP has problems with their DNS servers. But that is rare in comparison to misconfigured computers.
If your PING tests work but you are having problems browsing sites on the Internet
1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured.
2. Double check that you don't have an incorrect or not needed Proxy server assigned.
For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Jun 18, 2010 | Dell Inspiron 1545 Notebook
Trying to reconfigure the router and a message comes up "unable to connect to router" I've done all the steps even reset to factory settings.
If you've tried reseting it, then the IP address is probably one of the following:
192.168.1.1
192.168.0.1
If you know how, try to ping the router via command prompt. You can do this by going to:
Start Menu>Run
then type
cmd
A black window will appear, try typing:
ping [one of the IP addresses above]
if nothing "replies" then you have a bad connection. If one of them does reply.
Try typing that IP address into the browser address bar to bring up the routers web interface.
If it's a linksys, try this for the username and password
Username: admin
Password: admin
for Netgear:
Username: admin
Password: password
Apr 03, 2010 | Linksys Wireless-G Broadband Router
Internet connection problems
Troubleshooting Internet Connection Problems The purpose of this section is to give general tips
on troubleshooting your Internet Connection
While there are many possible configurations, I'll try and cover the most common ones.
Making Sure You Have Correct IP Information
Basic PING Tests
Browser Configuration
Making Sure You Have Correct IP Information 1. Make sure you have the correct IP scheme for your network. This would include the:
  • IP Address
  • Subnet Mask
  • Default Gateway
  • DNS Servers
2. There are a few ways you can see what IP addresses are being assigned.
But generally for:Win9x - Start / Run / command
Windows2000/XP/Vista - Start / Run / cmd
ipconfig.jpg 3. IP Address:
192.168.0.x, 192.168.1.x or 10.0.0.xIf you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
4. Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0 5. Default Gateway:
Make sure you have the correct Default Gateway IP address.
With a router, this is typically the IP address of your router. 6. DNS Servers:
Make sure you have the correct DNS Servers. Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
7. Possible causes for not getting an IP address assigned are:1. Defective cable, network card or port on the router. Make sure you are using all known working components.
But you need to have this correct before proceeding.
Basic PING Tests 1. This and can be done from that same command prompt you used to run IPCONFIG 2. Try pinging the router's IP addresse.g. ping 192.168.1.1
3. Try pinging an external site by IP address e.g. ping 4.2.2.1
3. Winsock Fix - It is possible that the Winsock Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Namee.g. ping www.yahoo.com
If your PING tests work but you are having problems browsing sites on the Internet 1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured. 2. Double check that you don't have an incorrect or not needed Proxy server assigned.For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Mar 28, 2010 | HP Pavilion dv9720us Notebook
Just bought a phillips modem/router and cant get to connect to the address http://192.168.2.1/setupw.stm can any one help?
Reset and power cycle the router for 30 Seconds, then first check the Gateway address if its 192.168.2.1 as per your post then first try to ping that IP address and check if you get the reply from that address, if 4 sent and 4 received then after entering that IP address on the browser you should get a login screen,use the login credential provided to you by the router manufacturer, you should be able to get in.
Mar 27, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I log in to a motorola cable modem??
Depending on what model of "modem" you have you may not be able to. If the Motorola unit is just a modem (not a gateway) then you can't, and you don't need to. There is nothing that needs to be configured in a modem.
If the "modem" is a gateway (a modem and router in one physical unit) then you need to open a browser (Internet Explorer) and enter in the IP of the router. For example, http://192.168.1.1. Depending on the model of the unit, that IP address (the numbers) may be different that what I typed. You can determine what IP address it is by looking at the product documentation, or double-clicking on your network connection icon in Windows and reading the "Default Gateway" address.
Once you get the correct IP address entered into the browser, the page for the web interface will load. That is where you can configure it.
Jan 18, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
Getting a router signal, but no internet
Have you check if you have a valid IP address? You could run IPconfig in the DOS window to verify this. If you have a valid IP address, try pinging the default gateway (You should be able to ping it.) Then, try to ping a website. If you could ping a website or URL but still can't browse check your firewall settings and optimize your browser.
Please post here what happen.
Thanks and regards,
BeHar
Jan 18, 2009 | Linksys (WRT54GC) Router
Pc desktop
after you format your computer u need to install the drivers for your internet.....install the driver for your network and u can go live
Mar 08, 2008 | Computers & Internet
Cannot go on line
is it only website you cannot go to ? or can you not connect to the internet at all ? What system are you using desktop/laptop? connecting via modem? router? dial up? wireless or ethernet ? Was this computer on the internet before and now will not connect, or is this the first time setting up connection?
DNS Problem
hi, try to disable or reinstall your modem, then reenable it, see if you have dinamic DNS or DHCP on. or you have static ip?
check your router too.
Carl
Nov 06, 2007 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
