HP laser jet 4000. Paper goes through with no print even on a printer sample request. New ink cartridge fitted.
  • luapx Mar 07, 2008
    drivers have been updated. Suspect some internal hardware problem
  • tonersmart May 11, 2010
    look on the side of the printer where the fan is. Theres a little hole directly below the fan, it is the engine test button.. sitck the shank of a q tip in it,...it is a little micro switch........does it print anything????
Check the Drivers installed, upgrade your drivers from HP site.
Posted on Mar 07, 2008
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have a HP Photosmart C4280 All-in-One printer and it prints information crooked on my paper and makes a little crease on the page. I have taken all the paper out of the try, reloaded it, checked the...
Hello Sherryjean,
I know how frustrating this issue is.
I request to perform the steps provided in the following Hp web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01124255&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search
If the issue persists even after performing the above steps, please try with different type of paper. If the issue persists, then it will be a hardware failure and please contact the nearest Authorized Service Provider to repair this unit.
I hope the above will resolve the issue.
Note: HP PhotoSmart C4280 all in one is not a Laser Printer but a ink jet printer. :)
Regards,
Tony
Jul 15, 2011 | HP PhotoSmart C4280 Laser Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
We installed our new computer and printer..however the printer is not printing out anything. Its working..but no print on the paper. We took the tape off the cartridges. Help!!
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles",
to s(t)uck ink from the ink-cartridges into the ink-jets, and to unclog any of the ink-jets
that should be shooting the ink onto the paper.
Or, since it is a NEW printer, exercise the WARRANTY to get it repaired/replaced, at no cost to you.
Jan 10, 2011 | HP Photosmart Premium C309g multifunction...
Hp 5510 printer/copier/fax/scanner will not print docs. The paper goes through but nothing is on the paper. Tried to print test page, same result. I've checked the cartridge - not empty. Haven't used the...
It sounds like the jets on your cartridge is plugged. I have unplugged some cartridges by soaking the jets in alcohol. I pour some alcohol in a shallow dish and set the cartridge in it with printing jets down. Leave it for 5-10 minutes. If the jets start to unclog you will see the ink discolor the alcohol.
Be careful when wiping off the ink jets so you don't damage them. Use a soft cloth. Try the cartridge and see if it prints. If you need to soak it longer.
Jul 13, 2010 | HP Officejet 5510 All-In-One Thermal...
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
