Question about Sanyo DP50747 50 in. Plasma TV
On a Sanyo DP50747 TV. The picture screen goes grey and the sound will go off for 3 or four seconds and then come back to normal as if there is nothing wrong. Green light for OFF or ON does not fluctuate during these events Doug
Mine did that and now it has no sound or picture. Be prepared for a dead tv soon.
Posted on Mar 15, 2010
SOURCE:
My sanyo tv model DP50747 has sound but no picture
check your cables there are normally two audio and video , check the video input or press it properly in the TV socket
Feb 20, 2015 | Sanyo Televison & Video
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
My tv does a clicking sound then goes completely black and no sound for about 3 seconds it does this about every 10 min
Working on same model at the moment - i'd check your power supply to make sure it is getting the right voltages and if it is i;d concentrate on the main board.
thanks,
michael
Feb 07, 2011 | Sanyo DP50747 50 in. Plasma TV
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Sanyo DP50747 50" Plasma sound but no picture green light is on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 25, 2017 | Sanyo DP50747 50 in. Plasma TV
Have a Sanyo Plasma TV DP50747 and both picture and sound all of a suden went. I turned it on from the remote and the green power light goes on, but no picture or sound and the power light goes off again...
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Jan 10, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Sanyo dp50747 Plasma HD TV
I just had mine fixed and the guy said " ITS THE POWER SUPPLY" tv nows works fine after repairs but my ps3 won't work on this tv any clue or is it just cheap engineering and I just get what I pay for!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dec 28, 2008 | Televison & Video
sanyo recommends using the reset button with cable box on, vcr off and press the reset button 2x, then try pressing channel up button if no message appears on the screen. i have not trid it yet... but good luck
Sep 23, 2008 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Sanyo DP50747 50 in. Plasma TV Logo
390 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
