Question about Atlantis Crystal Uniden Atlantis 250 Handheld VHF Radio (BLACK)
Help with antenna
Hi, I have the Midland VHF handheld nt ivp radio..
Iwant to connect a exteral whip antenna to it.Is it possile and if so how can I do it? plus does it need to be matched?
Thanks ,
Dan S.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
I think the whip antenna is for mobile,I suggest to get an aerial antenna even an omni type and of course the impedance is 50 ohms and try this antenna a cushcruft the model s ringo ranger 2, it is tunable antenna,I already test it from 2001 up to present,its working fine...
Posted on Mar 13, 2008
I have a midland 2 way radio trying to transmit and receive without static
If a handheld radios check your battery and/or antenna. Trade with a known good unit to see if the problem is solved with either. A poor battery can often cause static.
If a mobile radio, check your antenna connections and your antenna and coil. This could be a sign of a poor antenna or antenna set-up.
Best regards.
May 15, 2015 | Midland Radio Communications
Does a midland cb 40 ch have a range for distance?
  • Hi, I can help.
  • In general a CB goes roughly 1 mile per watt of power. A Midland CB out of the box will get you about 5 miles. After a Peak and Tune, a Midland CB can get out around 25 miles. If you put an SWR/Watt meter inline you can tell how much your rig is putting out.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
regards, Tony
Sep 01, 2011 | Midland Radio Communications
I have spotty reception on a handheld CB and was wondering if there is a testing procedure I can use to check the antenna and radio. I have a multimeter. It's a radio shack handheld with weather bands...
The antenna is your problem not much gain. Height is everything tx and rx. Although it would not compare to a conventional cb size negates performance. Seeing is believing in this case hearing get adapter to connect to standard coax of antenna. (PL259) to BNC Coax Adapter Radio Shack sells them. And dont ask or buy any radios there. They are hardly the radioshack of choice anymore.
  • If you put 4 watts into a four-foot antenna, you will get the same power out of that antenna as if you were putting 2 watts into a 102-inch whip.
  • If you put 4 watts into a 3-foot antenna you will get the same power out as if you were putting about 1.5 watts into a 102-inch whip.
  • If you put 4 watts into a 7.5 inch antenna on a hand held CB, it would put out as much power as a third of a watt into a 102-whip.
  • If you put 4 watts into a 102-inch whip antenna, it is the same output as if you put 11 watts into a 3-foot whip.
  • If you put 4 watts into a 102-inch whip antenna,, it is the same as if you put 14 watts into a 28-inch antenna.
  • If you put 4 watts into a 102-inch whip antenna, it is the same as if you put 54 watts into a 7.5 antenna.
May 21, 2011 | Cobra HH 38 WX 40-Channels Handheld CB...
Plug portable whip antenna into radio, power on with car lighter, no reception...how do I tell if radio itself is not working properly
To check your radio you will need a ANTENNA RADIO TESTER Shakespeare make a cheap tester STYLE: ART-3 works good. Good luck.
Jan 22, 2011 | Uniden Solara Vhf Dsc Fixed Mount Radio
Is it my CB antenna or something else
First off, Midland makes a fine radio. Make sure your squelch is turned all the way down to receive distant signals (down meaning counter clockwise). The through the glass antennas are not the best thing in the world. I personally use a 102" whip and a 6" spring on a modified mirror mount. It is installed on the tailgate side of the tool box. The TX and RX is amazing. Wilson and K40 make great antennas also.
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
S it my CB antenna or something else
take a 9 foot wire to the bad radio put the the wire into the center of the ant jack a see if you can hear your buddy glass mount ant are ****.
9 foot whip is best in car/truck 4 foot fiberglass cophased are next 4 foot are next mags are ok but over time and moving around they will mess up you paint
Too much static can not here police calls
Check to see if antenna is connected, if it is you may have to buy a higher gain antenna. More info would be nice next time.
May 27, 2009 | Uniden HH940P Handheld, programmable...
MIdland no sound s/rf dancing
may be u burned yr final transistors...check if yr antenna is well grounded and try just after this to transmit, if the indicator is not stable on the green area when you are in "am" modulation stop to try and bring to the assistance
rgds Stefano
Dec 17, 2008 | Midland 1001Z 40-Channels Base CB Radio
I recently purchaced 2 Midland CB radios and headsets to go on two motorcycles. When I use them I get excessive feedback. It appears that the metal motorcycle handlebars interfere with the rubber antenna....
The problem is with the headsets, not the motorcycle. If the headsets are generic they may not have the proper mic connections. How do the radios work without the headsets?
Jul 11, 2008 | Midland 75-822 40-Channels Handheld CB...
Atlantis Crystal Uniden Atlantis 250 Handheld VHF Radio (BLACK) Logo
172 people viewed this question
Top Atlantis Crystal Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Atlantis Crystal Radio Communication Expert? Answer questions, earn points and help others
