Fault on TV
Our Toshiba TV - 36ZP46P has had a problem after 3 years without fault, worked this morning ok, but this afternoon suddenly had problems when switched it on.
It appears to have lots of lines across the screen, lots of colours as if it cannot put the picture together.
Bottom half of screen is black and the top half has loads of horizontal lines, any ideas?
  • blakerp Mar 14, 2008
    It seems that Toshiba must know they have a problem with this model as they have offered to send the part, free of charge, to their authorised repairer, who will then pick up the TV and take it away to repair.
Something fried .. sounds like the vertical has gone ,
call a tech.
Posted on Mar 14, 2008
Good afternoon, Sirs! I bought an LCD TV Sony KLV-32S200A four years ago. Yesterday the TV didn't turn on. The standby light blinks 5 times and pauses for 2-3 seconds, then blinks 5 times again. Could you...
Hello
Blinking of standby light is Sony TVs are fault indication. Five blinks denotes
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. You must have some knoledge in electronics and ability to follow the schematic diagram of TV otherwise called as circuit. Must have a high quality digital multimeter, soldering iron and a concept of soldering. I'll assist you. Must have confidence and more patience. If you have these, inform me by Fixya. I'm happy to assist you. If not, get it repaired by Sony Authorised service center. Any service center, who takes this set for repair, must have all the testing equipemets like oscilloscopes, clour analiser, pattern generator and AVO meter. Without these testing equpments, trying to repair this set will make things mor worse. OK.
Apr 09, 2011 | Sony KLV32S200 Television
I have a 42" Wall Mounted Plasma Screen TV Set have had it Now for aprox 5 Years with No problems at all. However this morning when I turned it on the Picture and sound was OK, and then the Picture...
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 15, 2008 | Televison & Video
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
We receive satelite tv through dish and digibox. We have suddenly
Try unpluging from the mains for about 2 mins,if still a problem then the LNB on the dish may be at fault
Oct 27, 2009 | Televison & Video
My screen become blank, one thin Horizontal bright line in middle of the screen appears
You have what we call 'frame collapse'. This has many causes and without fault finding, I cannot pin point the exact location of the faulty component.
Feb 13, 2018 | Toshiba MV20FM3 20 in. TV/VCR Combo
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
HAI,1.REPLACE SOME CAPICTORS IN HORIZONTAL SECTION.
       2.ADJUST FOCUS ON LOD(EHT TRANSFORMER).
       3.REPLACE HORIZONTAL OUTPUT TRANSISTOR.
Jul 05, 2008 | Televison & Video
32" Toshiba Television suddenly quit working
by the age of the unit it sounds like cold solder connections, on the main board
Mar 27, 2008 | Toshiba CZ32V61 32" TV
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
VCR not working with TV
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Aug 22, 2006 | Toshiba CZ32T31 TV
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
