Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Verticle blue lines, left side
Not sure why this would happen all of a sudden, but one of my Dell 2001fp monitors has started showing a band of translucent blue lines on the left side. The lines are about one pixel wide, and there's a bunch of them (top to bottom, for the full monitor height) that cover a width of about 1.5 inches.
I haven't disconnected or reconnected anything in over a year, and nothing seems odd about the monitor settings, which I also haven't changed. the rest of the monitor picture is fine, without any color distortion at all. I can see the desktop icons on the left side of the screen, but having that set of blue lines there is annoying.
Any ideas about how to get rid of these lines, or is my monitor dead?
  • 5 more comments
  • rmiller0323 Mar 15, 2008
    Thanks, Nathan. I suspected it was a hardware problem. Sounds like it might be.
    One extra ripple is that the vertical blue lines disappear sometimes after the screen saver disappears when I move my mouse after a period of inactivity.
    Does that still suggest the display cable is bad? Does having the screen go dormant for a while gives the cable a break somehow? That sounds a little strange to me, but hey, I'm not a hardware guy.
  • alvesd May 04, 2008
    I have the same problem. Same monitor. However, mine happens after about 5-10 minutes of being on. I am connected via VGA. Would this problem persist if i use DVI?
  • KayMan2k May 12, 2008
    I have the exact same problem. but my lines are yellow instead of blue.
  • ciber13 May 23, 2008
    my LCD 2001fp has 2 bands of vertical lines red and multicolored on left side of the screen. What i can do?
  • Anonymous Oct 09, 2008
    i have the same problem with my monitor... but it's not a monitor goin bad.. cuz i just replaced it 2day.. with a flat screen tv/moniotor.. but im still havin the same problem.. i have the baby blue verticle lines everwhere about a pixle in width.. startin to get a lil frustrated.. but this obviously leads this problem to be on the PC side.. is my graphics card takin a poop or wat? im confused.. soo if someone could help me out and may b let me know wat the problem is.. id highy appriciate it.. thank u.. Travis, pennsylvania
  • Anonymous Dec 10, 2008
    I got the same problem today with one of my monitors and I switched the connection cable and it does the same thing. I think it is the monitor and not the cable. when it cool down sometime the blue band disappear for a shot time. it shows up after a while. I would think changing the monitor is the solution. any other idea?
  • Anonymous Feb 25, 2009
    I have the same problem. The left vertical lines appear about 5 minutes after I turned on my monitor. I already called Dell tech support and they said it is the LCD problem. They couldn't do anything for me unless I bought their extended warrantee. I think dell had a bad batch of LCD panels made in korea at a certain year, from reading some of the forums. I also own another 2001FP which works fine.
    LCD monitors are now not expensive, so the bad monitor is e-waste, sell the ac adapter on e-bay.
  • 55 Answers
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Posted on Mar 14, 2008
Mostly the line bar problem especially from top to bottom is the driver tabs that go from the panel controller board to the panel itself.
Posted on May 17, 2011
I had the same vertical color bar problem this morning when the monitor got warm. We are not alone. Check this out:
http://gadgets.boingboing.net/2007/09/07/headscratcher-my-lcd.html
Posted on Dec 27, 2008
  • 21 Answers
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001 fp monitor has 2 blue horizontsl line on left side of screen and sometimes become white block
This not good! the problem is in the LCD panel display, and there is no way to repair this on a practical scale, this would not be a cost effective repair, far cheaper to replace the monitor.
Feb 07, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP vertical band issue
I'm having the same problem... there's also going to be about 5 years of dust sitting in there, so I hoping it might just be a failure of convective cooling. My first attempt to remove the bezel was unsuccessful, so I wasn't able to go in and look for any swollen capacitors or such. I have blown canned air in the sides, and it's actually doing a little better right now. Probably won't last... having a rather warm summer.
Jan 22, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Suffering from EXACT same problem. Also Dell UltraSharp 2001FP
This is heat, and is a common problem; it affects two of mine. You can verify this by having a can of Dustoff available and catching it when it first starts. Blow in at the top of the monitor through the holes in the back in the same region as the band. The color aberration should go away.
My solution was to make a shroud from black foamcore and use a spare power supply fan to blow air into the case at the top. This has worked for my two monitors for about 18 months. You can also just buy a 12v computer cooling fan for this purpose.Should be somewhere around 75mm in size and quiet, 'cuz you'll be putting up with it if it's not.You can either get a general 12v power supply, or an adapter that fits the 12v power out at the back next to the USB input connector.
Sep 04, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My monitor suddenly always shows like 4 verticle lines near the edge of the right side of my monitor.Red, light blue, light blue and green to be exact. What made this happen and how can I get rid of it?
The lines could be caused due to the disturbance in its radiations.in other words,look around the monitor to find if any other gadget like a Microwave Oven or Magnet is placed.
You can see if there is any leakage that ends up dropping water on the monitor.
you can see if the air cooler or conditioner or heater is directly blowing air on the monitor which could cause this to happen.
If you want to Isolate if the issue is really with the monitor or not, you would have to try out another monitor at the same location and observe for 24-48 hours.
Apr 24, 2009 | Acer Computers & Internet
2001FP LCD Half Display
please refer to this link for help..
http://support.dell.com/support/edocs/monitors/2001fp/EN/trouble.htm
Sep 09, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
BENQ MONITOR
I will assume the line goes from top to bottom and is straight.
If so bad news I am affraid. It is the driver tabs that go from the panel to the physical panel controller board and is not making correct contact.
This will normally continue to get worse until you lose entire bands of the screen.
Sorry for the nad news.
Dec 13, 2007 | BenQ FP767 17" LCD Monitor
Dell 2001fp - Ramdom horz strips
Just had the same issue with the horizontal lines. In my case, too, turning off the monitor would make it go away for a while. called Dell, turned out it was still under warranty (3 years), got a replacement monitor the next day. Way to go Dell!
Dec 05, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
1,375 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
