Question about Proscan PS32125 32" TV
Tv shuts on and off by itself - Proscan PS32125 32" TV
  • tucc Mar 07, 2008
    my tv sucks
    Novelist:
    Champion:
  • 236 Answers
I've had this problem a few times and I found a bad solder connection in the base circuit of the horizontal output transistor. It's a small inductor (coil) that has a poor solder joint.
A drop of solder on this will cure the problem.
AS team tech also said you may have a flyback bad.
Stargazer
Posted on Mar 16, 2008
    Scholar:
  • 133 Answers
This tv may have a defective flyback transformer . Your chassis # of this set indicates it is ctc197 . some of these sets also had weak caps in the power supply or loose connections in the horizontal section . If your set clicks like it is coming on then clicks right back off and does this a few times then i would say it is the flyback transformer . If not suspect the other circuits as your problem . A shop might charge between $80.00 to $120.00 to fix it . If you can't fix it , call around to get the best price . Good luck
Posted on Mar 14, 2008
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
Feb 06, 2018 | Televison & Video
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself off
The power supply may be going on to protection mode. This is usualy because one of the scan amplifiers may have failed, or something is taking too much current and forcing the power supply to shut down.
Jerry G.
May 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV shuts itself off after a few minutes. Will also shut itself off if the DVD open/close button is pushed. Not sure if a DVD is in the machine or not. Any ideas??
I know that shortly after I purchased this tv mine also shut itself off occasionally. The owners manual says that if it is on dvd mode and it's paused or on an inactive menu or something for 15 minutes or so that it would shut itself off. If a dvd is stuck inside it may be causing this? I have no idea about the open/close malfunction.
Sep 29, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Televison & Video Logo
109 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
