Question about Refrigerators
Refrigator run for awhile than Overloads breaker
The Refrigator seem to be working find and than you go out and it has trip a breaker. Changed to different breaker and does the same thing. Do you have any IDEA's? Thanks Tom
  • 4 Answers
UNPLUG!! CHECK THE RELAY THATS is in the back conected to the compresor if it has a white relay then its proably bad . you can take it off shake it and if it sounds like a salt or pepper shaker .then replace that. but if the compresor keeps on clicking the you have a bad compresor . and it exceeds the cost of the fridge
Posted on Mar 14, 2008
You must have fault on the fridge circuit
if you have checked relay on motor and is ok then possible defrost element fault check element with meger for fault to earth
Posted on Mar 15, 2008
TRIPPING BREAKER
get in an electrician to check the equipment and the circuits
Aug 29, 2017 | Heating & Cooling
Trips breaker once in awhile.Not consistent. Replaced elements, contactors, wash motor. Still trips once in awhile.
check for a bad connection, if there is a bad connection it could draw more amperage then it should.
Jun 25, 2015 | Hobart C44a Commercial Dishwasher
Furnace runs awhile then breaker trips
Electric furnace I assume- check with amp meter, if amps are below listed on breaker, replace the breaker, [check both the breakers in the furnace and in the house pannel, even if only one is tripping right now, the other(s) may start doing the same thing after you eliminate the weakest link- don't be surprised!] electric furnaces are notorius for "eating" breakers- they overheat the breakers for years then the breakers get weak and trip too easilly... if gas, post more info and I'll try to help further.
Feb 20, 2013 | Heating & Cooling
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Overheats and trips off
internal thermal over loads in motor are working properly! how old is the motor? double check all vavles on the intake and discharge line to make sure that they are open? sounds like the pump is pushing against what is known as dead head pressure. obstruction in discharge line! if valves are ok you can take the jet covers off (the piece that helps direct flow of water) which will relieve some of the pressure should allow it to run without tripping tgermal overloads. if none of this works replace motor!!
May 28, 2009 | Smith AO Pool Pump Motor
Breaker tripping
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 14, 2008 | Roper REX4634KQ Electric Dryer
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Jun 05, 2008 | LG L1004R Air Conditioner
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
