Maytag Model# LAT 8616AAE. The timer seems to work(runs/moves), but certain cycles are missed/bypassed.
Sounds like the motor could be cutting out on overload possibly
motor has built in overload
check this first
if cutting out possible faulty bearings in motor
replace motor
Posted on Mar 15, 2008
Anyone know why
If the machine has a mechanical control, the timer is stuck in a certain position. Whatever cycle it is stuck on will continue to run until the timer is advanced to the next setting. If you have an electronic board controlling things then that board is defective and needs to be replaced.
U might try unplugging unit to see if that affects the electronics. If manual timer, unplug unit and move the cam yourself to the next position.
Aug 06, 2015 | Maytag Washing Machines
Maytag Neptune MAH-1 front load washer won't spin in some cycles I use often. it spins at the end of the cycle and in cycles I do not use often. it spins in the spin cycle when I run that cycle
sounds like the timer is not advancing is certain cycles? timers have contact points that can burn and seize up sticking close and not allowing the next cycle to move
Mar 16, 2015 | Maytag Washing Machines
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Maytag performa washer only spins on 1 of 3 cycles.
This machines timer is bad ,basically you have bad contacts in the timer ,that why it only works at certain parts of cycle
Nov 20, 2013 | Maytag Washing Machines
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag Lat 8434 Top Loader will not cycle
sorry but i dont have much experience with this particular model, so i really have no advice for you, please repost
Dec 03, 2008 | Washing Machines
Maytag Washing Machine Problem
yes it does sound like a bad timer
Nov 25, 2007 | Washing Machines
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
