Sorry this brewer is usually set up for a full pot brew. I have reset this for a small (but not half) pot brew as the customer wanted to use a metal carafe (with their own logo). I also tried once to get it to half pot brew but it can get tricky if you actually brew twice to get a full pot (in the same pot).
* there is a siphon action that starts once the boiler tank gets filled to a certain point. From that point it will continue to flow until the boiler is emptied to the level that stops the siphon action and leaves enough water in boiler to reheat for the next brew. Achieving the siphon point may be a larger volume of water for 1/2 a pot but may work for 3/4ths a pot. The 1/2 way mark may be affected by the brewers "level" while placed on a table or sagging in the middle of a weak table.
* Usually if you want a smaller brew then go with a smaller brewer. Though there is a hot water tap that will give you 2-4 cups of hot water (it gets tepid after that) which you can use for the "Mug" style brew. But it does get messy.ukeboy57
* Final, If you don't mind a little more than 1/2 pot brews then ask your vendor to adjust the machine for you. Though a reminder NOT the double brew in the same pot as it will overflow.
Aloha, ukeboy57
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
The A10 has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
PS. Check your using the correct size decanter for this brewer. If it's a 10 cup brewer then make sure all the decanters in the office is also 10 cup. Pouring a 12 cup pot into brewer will have 12 cups of coffee come out (over flowing the 10 cup pot.) Note that not all decanters are made the same size. Other brands may be different. Test by filling a pot with water (from faucet) then pouring directly into pot in question. It should match and not under fill nor over fill.
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
The GB Siesta Oro was sold with a "Reducing Filter". This filter allows you to make half of the amount of coffee stated as the capacity of the pot. It is the mesh disc with the small stem that sits on top of the coffee after you fill the filter. If you want to make half the capacity of your pot, fill the chamber half way and use the reducing filter. If you want to make the fill capacity, fill the chamber completely and don't place the reducing filter on top of the coffee. Good luck. I hope you enjoy your pot as much as I enjoy mine. Ciao
Enough to submerge the fish in the basket. Easiest way to get it pretty close: 1. Place the basket in the cooking pot. 2. Fill to the estimated displacement with water. The estimated volume would about half the height of the basket in the pot, if you were to fill the basket with fish half way. This way you know that you'll have enough to cover the fish when you start frying. 3. Measure the water. If you have the markings stamped in the side of the pot, this is pretty easy. Otherwise, pour the water into a gallon jug, keeping tally on how much water you removed from the pot. A partial gallon at the end is easily estimated. Works the same for liters, depending on where you live. 4. Dry the pot thoroughly before you add the oil.
Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
If pot used to fill all the way then check the filter if one is installed and the restrictor on the back of the tank, you can also run the deliming spring through the brew tube. If the pot never filled all the way then remove the front panel and use the instructions to reprogram the brewer.
About two pots. After it is filled the first time, it should require only what you make the next time. Example: if you put in half a pot of water that much will come through.
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
