Carefully pry the chrome ring from the gearhead of the mixer. Item 28 on this page :
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
You will find 5 screws under the chrome ring. Tighten them and the oil (grease) will stop leaking from the gasket which seals the gearcase halves.
It has been brought to my attention that on some models removing the ring does not completely expose the screw heads. On my machine I was able to access the screw heads without removing anything else, however you may need to remove the rotating part to access the screws. Todo this you simply drive the pin from the drive shaft and remove the planetary housing (#33) to gain complete access to the screw heads.
