Overheating with certain programs
I have overheating problems with my laptop, Packard Bell E3245, when using certain programs, like
You tube,
listening to music (watching video is no problem though),
with scanning, if document is long,
with Skype, if other websites are opened.
In these cases CPU goes up to 98%, in a few minutes the computer becomes too hot and it turns off unless closing the program mentioned above.
Listening to music from cd or from files wasn't a problem before, until about a year ago.
Otherwise computer and fans work properly, the air vents are not blocked.
I would really appreciate if you could help me what to do.
Does updating BIOS help?
Thanks a lot
  • jeannie1999 Mar 10, 2008
    I cleaned the air vents with compressed air and then removed the battery. After that I tried to listen to music and it was MUCH better. Although the fan is on all the time, it is not loud and the computer doesn't heat up (and doesn't turn off!!).
    I had a look at Packard Bell updates before on their website and I will do the bios update as you suggested, hopefully will help even more.
    Thanks a lot for your comments&help!!!
    President:
  • 2,351 Answers
Hi jennie,
One of the most common problems with older & a lot of newer notebooks has been battery's over heat & the system shuts down. I suggest you remove the battery & run off the AC power cord. Run the programs you mentioned & see if the notebook shuts down. This is only a test.
Packard Bell has a site where it can Diagnosis & Repair some problems loacated at this link. Try it.
http://support.packardbell.com/uk/item/index.php?m=home&pn=P820000001
Posted on Mar 07, 2008
  • Mike Peluso
    Mike Peluso Mar 07, 2008
    Click Product Downloads for bios update.
Laptop constantly reboots
hi, is the internal fan working ? and if so does spin at a fair rate ? if it going slowly that's no good.
This can be a classic with those laptops overheating .
Regards
Dec 21, 2012 | HEWLETT-PACKARD HP G60-530US Notebook
Remove keyboard packard bell easynote LM
Nope, u need to remove whole panel AND keyboard to get acces to motherboard, take one screw of and then u can pull out your motherboard and then u can acces to the fan.
The kboard comes of quite easyli, just press lil buttons(you can see em above f1-f12->) I used this as advice http://www.youtube.com/watch?v=Ayng3v482Hg
Not the same laptop but u will figure it out how to dissamble your laptop with this.
Mar 31, 2012 | Compaq Keyboard
I have a Packard Bell which shuts down after a few mins. start it back up and does the same took it to PC World they said it needs a new mother board this PC is only 13 month old they and Packard Bell will...
Simple test - open the side of the pc, boot into the BIOS and wait, if the pc shuts down then restart it in the BIOS and check the temperatures - if they are ok then the board is faulty and you must replace it, a similar new one will cost you less than $40.
Sep 15, 2010 | Computers & Internet
HI THERE MY PACKARD BELL 2215 IMEDIA WILL NOT BOOT UP. iT WAS WORKING PERFECTLY THEN IT CRASHED NOW IT STARTS, FANS SOUND, BUT THEN IT SWITCHES OFF, ANYONE HELP? X
Sounds like an overheating problem. Clean the dust out of it, make sure it can get air on all sides, make sure the fans are turning. If that doesn't work, unplug the computer, hit the power button 20 times, wait 1/2 hour and boot it up.
Apr 22, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Packard bell utow co20 the computer will stay on for as long as I dont use it, but as soon as I start useing it it will shut down in about 5 mins
First things first: "work" in giving this away has dodged the "responsible disposal" bullet. Drivers for this unit are probably limited to windows 98 or earlier, as the last Packard-Bell was produced in that era. Drivers for sound in particular were Packard-Bell only, and since they aren't around any more unless you can get your hands on the original installation CD you're out of luck to make the existing soundcard work. You do howrever have the option to install a newer soundcard, that should fix that issue. As for the shutting down, make sure the heatsink has good thermal contact with the processor as it sounds like the processor may be overheating. If there's a fan make sure it is running.
You've got a challenge if you want to see it all work, have fun.
May 30, 2009 | Packard Bell DR724 Motherboard
Laptop chargers
Probably you damaged the motherboard with an incompatible charger, You are very likely to need to have it replaced and to buy a fujitsu spare charger or at least an aftermarket compatible one...the charger might have broke instead because of overheating caused by the higher load, but cannot be sure about it because you didn't post full specs.
Jan 31, 2009 | Computers & Internet
Back up problem
ok..got it...well...we can certainly make that happen
how much is the memory stick
and how big is the file you are backing up?
Oct 20, 2008 | Packard Bell Easy One Silver 2120 Notebook
I have the laptop on for so long and it switches itself off all the time
Hi
We had the same problem so I bought a cooling tray from ebay for just over a £10 and it has worked a treat. The tray has 3 fans built in that blows cool air into the laptop, it is powered by plugging it into a usb port. Hope i have been of use
Regards
Paul
Oct 15, 2008 | Packard Bell Easy One Silver 2120 Notebook
My power adaptor wont charge my laptop. Where the adaptor goes into the laptop it is singed. does that mean it has overheated and blew the motherboard.
No, that means there is singeing where there should not be singeing. You can get your adaptor tested free, and you can also get your battery tested (they only last a year or two, depending on use.)
You filed your problem under Packard Bell PC Desktops...and it's for a laptop.  Start over!
Jul 31, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
