Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Lens will not retract
Turn camera on it beeps at you and turns back off and will not retract the lens.
  • 108 Answers
I had a Canon IXUS II do this.
Unfortunately it required a new lens which the repairer could not supply due to its age. The repairer replaced the camera for the same cost with much more recent model! The repair cost was £70 plus postage. (This was 4 years ago now when a new camera would have cost over £199).
If its under warrantee use it - Sadly it might be cheaper at todays prices to replace it instead of have it fixed.
Posted on Mar 07, 2008
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
I was just putting my camera in the case when I accidently turned it on, it beeped and I took it out of the case now the lens will not retract
Try taking the batteries out and put them back in. Turn the power switch on and then off and see if lens retracts.
Nov 12, 2009 | Onkyo HT-S680 System
Lens not extending
You have a lens problem. Sure it can be fixed but be sure to get an estimate first.
Aug 24, 2009 | Samsung Digimax S73 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Polaroid i735 Camera won't turn on. Lens stuck.
I had the same problem, and fixed it by wiggling the lens a little, when turning it on.
After a few tries, it finally wiggled free, and the lens retracted.
Jul 05, 2008 | Polaroid I533P Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
It wont stay on
the same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
May 14, 2008 | Polaroid i531 Digital Camera
Digimax 430 camera won't turn on
If your lens is open and the camera turns off after those dreaded beeps, I have a fix for your problem. Basically, for this model of camera, the lens first pushes out a bit and then it retracts into the camera. Well, my lens got stuck on the pushout and it prevented the camera from turning on. I used some finger pressure and wiggled the lens a bit. Then I turned it on and it retracted to where is was supposed to be to take pictures. Then I turned it off and it retracted into the camera. Problem solved!
Nov 05, 2007 | Samsung Digimax 430 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
