DEVICE MANAGER CODE 9001
HI THERE I AM HAVING TROUBLE WITH MY TOUCH ME FM37 PLAYER, DURING START UP SCREEN ITS SAYS DEVICE MANAGER CODE 9001 SEE MANUAL, I HAVE CHECKED THE MANUAL AND UNLESS IT IS MY BLIND PANIC OR ANGER I CANNOT SEE ANY INFO. TO SORT THIS? CAN YOU ADVISE ME PLEASE?
    Guru:
  • 1,894 Answers
Hello sir\
Posted on Mar 07, 2008
  • dewan nafees ahmed Mar 07, 2008
    do a hard reset
    this wil surely fix you
    thank you good luck
    dont forget to rate the solution
Tuchscreen not working
1.Windows key + Q.
2.Type Control Panel.
3.Go to Hardware and Sound.
4.Pen and touch.
5.Click the touch tab.
6.Enable use your finger as an input.
For more advanced users :
  1. First, go to the device the manager by opening the "Charm Menu" and search for "Device Manager." If you don't see it, change the search filter to "Settings."
  2. Once in the Device Manager, expand "Tab." Then find "Human Interface Devices" and expand it.
  3. You should see several "HID-compliant device" listings. Some PCs will call it an HID-Compliant Touch Screen, but yours may vary-if you don't have a touch screen option, you may have to try each HID Compliant ____ until one works. When asked if you want to disable the device, select "yes." That's it! The touch screen on your Windows 8 device should be disabled.
  4. Click link below for image if you are still having trouble.
http://i.kinja-img.com/gawker-media/image/upload/s--XFVjA7m---/buikrvv6mjnuqm8pv7pt.jpg
May 22, 2014 | Dell Computers & Internet
Hi, Have an LG MP3 Model: FM37. When the MP3 player is turned on it displays Device Manager Code 0001 See the manual When connected to the computer, it displays Devce Manager Code 9001 See...
For the error 9001 ,i have a solution buddy..Try to format the device (from the General Settings) and the error message doesn't come up anymore...But The fact is you will lose all you data stored in it..hope this helps you..
Also i will try to find a solution for code 0001 too..Thank you!!
Regards!!..
Jul 23, 2008 | LG Audio Players & Recorders
Hi team,i am facing problem with philips go gear 2GB player, Problem is :when ever i switch it on,"please connect to Pc and use device manager to repair" please help me in this scenario,explain...
I'm not a team member, but
1. Select your GoGear 2GB player from this list:
http://www.search.philips.com/search/search?q=GoGear+2GB&s=all&l=global&h=all&o=
2. When not having the program Philips Device Manager installed on your computer yet: Look under Software and Drivers, select the Device/Firmware Manager for your player.
2.1 Run the execute file Device Manager for installing the Device Manager toolbox.
3. Run Philips Device Manager:
  1. Having launched Philips Device Manager at Start -> Programs -> Philips Digital Audio Player -> SA2XXX -> Philips SA2XXX Device Manager on your PC
  2. Connect your player to the PC
  3. Device Manager should acknowledges your player and automatically goes into recovery mode.
  4. Follow the instruction of the Device Manager.
  5. After the player has been repaired, remove it from your PC and re-start.
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Feb 21, 2010 | Philips Audio Players & Recorders
Blank or purple screen, device manager claims to
Having a blank or purple screen, plus the device is not recognized by Rhapsody player, then this is an indication that the device has a corrupted program or problem with the circuit board.
The first thing that should be done with the player is to re-flash or upgrade the firmware (software). This is the best thing to do to reprogram the device without opening the device itself.
If that did not help, that's the time that the internal components (circuit board) should be checked, to see if there are bad components that needs to be replaced.
These things should be done by the manufacturer, so that you can be sure that your device is in good hands.
Good luck and have a great day!
Feb 15, 2010 | Philips GoGear SA5285/37 Digital Media...
My GO Gear not starting
Did you try pressing the reset button on the bottom of the player next to the hold switch?
Mar 06, 2009 | Philips GoGear SA3245/37 Digital Media...
Many problems in using the FM37 media player. I wish I had bought the next Philips up from the 2GB model I have. At least they 100% know how to develop decent software, even a child could use. Using any...
I did solve the problems with the LG FM37 media player. After the download of the LG FM37 firmware to the latest version 2.20EN, the device kept mentioning "download & press record". As nearly every function is controlled by touching the screen, I pressed where it said "record" in the message. Of course to no avail. Then I though perhaps it is suggesting the voice record button on the side of the device, and when pressed the device did it's thing and transformed to version 2.20. When I turned the device on, all the files had become question marks, and nothing functioned. In fact I could not turn it off. So, **** the reset/microphone hole with a needle, I decided the best thing to do was to format the thing from the settings selections. Prior to the re-format, the device kept mentioning "error code 9001". That disappeared once the device was re-formatted. And that did the trick, once the re-format was done, there were no files, for sure, - but the first video a Donald Duck cartoon from Youtube was successfully downloaded. Previously I had been using a free on line video converter to convert the Youtube FLV to AVI - which is what the FM37 converter changes files to, then I would run that through the FM37 LG converter to size for the device. But it seems happier to have the FLV converted to WMV. I use the free "Any Video Converter", then to run that through the LG media converter, which it transforms to AVI. Since the re-format of the device and the conversion thing, the videos have all neen synchronised normally. I haven't solved the "Library" issue on the LG Media Converter, which still thinks there are a lot of files in the Library, which are no longer on the device. There is no delete facility, - crazy. But Windows media does allow you remove files from the device, but if set to automatic synchro, Media Player annoyingly reinstalles them in the device. Change Windows Media player to manual operation, to stop that. I don't know what changes firmware version 2.20EN made, but one useful thing is a "trash bin" icon at the top of file contents (videos in this instance). You can click on the file you wish to delete, then the trash can to delete it there and then. Useful for files you downloaded to the device without converting, for instance. However, it seems the LG Media Centre *will allow only an AVI file through (without further processing), but if not converted, the device itself will just show an error message and play the next video. The Philip's "Go Gear" Media Centre would *not allow you to download incorrect files. I like the way the LG plays all the video files one after the other, without intervention, as does the Philips (which can also repeat). That is the main reason I didn't buy Creative Zen, as one always has to return to the menu to selct the next video.
Oct 06, 2008 | LG Audio Players & Recorders
Hi, Screen displays 'Device manager, Code 0001, see the manual' on LG MP3 Model: FM37. Cant find anything to do with this in the manual. Thanks
download the manual:
http://mx.lge.com/support/support.jsp
If “MTP Media Player”window is displayed when the FM37 is connected to PC, click the “Cancel”button.Above window may not be shown as the Windows user settings.
Select the “LGE MTP PLAYER-FM37”in Windows Explorer.“LGE Internal Storage”folder will be shown.Copy the “FM37.ROM”to the “LGE Internal Storage”folder.Copy the “FM37.PAC”to the CONFIG folder.
Jul 23, 2008 | Audio Players & Recorders
Device problems
I'm sorry you're having trouble. It appears that you are having driver issues. You don't mention if the built in keyboard is displaying symptoms of any kind, or if there's any informations with regards to why it doesn't work. Also, you say you are using a cordless mouse, but that would be a usb device (As far as I am aware, I've never seen a ps2 cordless/wireless mouse) If you could provide further info i that regard, it would be most helpful. Thanks, and good luck
Sep 08, 2007 | Acer Aspire 5100 Notebook
Problems with LG MP3 Player (due to a mistake in the operation of the device)
I too have had the "Device Manager code 9001 see manual" message come up on my LG unit, after having upgraded the firmware. All my music and photos disappeared and the unit would lock up if I tried to record anything.
I decided to format the device (from the General Settings) and the error message doesn't come up anymore. All my stuff was gone so there was nothing left to lose. It seems to be working now. I hope this helps you guys too.
Jul 03, 2007 | LG Digital Media Player (MFJM53)
339 people viewed this question
 Grubhead
Grubhead
