Check the idle up or the magnetic valve
Replace fuel filter than check fuel pressure because it started when u sprayed it so ur problem is in ur fuel delivery -if fuel pressure is still low or none check connection at fuel pump sometimes corrosion builds up between connections if good and full power and no pump pump failure and need to replace good luck
Thanks for the quick response but I am a little confused on the "idle up and the magnetic valve". Can you please elaborate.
