Question about Baby Gear
1998 Mercury Sable window washer pump repair?
Where is the pump located and is it an easy fix?
  • 2,039 Answers
On passager side in the windshield washer container easy fix 11mm socket remove container change pump that it thanks for using fixya pierre
Posted on Mar 08, 2008
2001 mercury sable wagon rear winshield washer pump location?
If I'm not mistaken, the pump shares the same washer fluid tank up in engine compartment. Tank has 2 pumps
Dec 06, 2017 | Mercury Cars & Trucks
Locate water temp gage on v6 engine 1998 mercury sable
The second picture down on the left .copy and paste the below site.
https://www.google.com/search?q=1998+mercury+sable+temp+sender+location&client=ms-android-americamovil-us&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiu9bev5sjVAhUExoMKHUzIDdcQ_AUIEigC&biw=360&bih=513#imgrc=byCw3mkwV_fgOM:
Aug 08, 2017 | Mercury Cars & Trucks
Fuel pump relay location on 98 mercury sable
its under the hood on driver side what the problem not starting check the trunk area for the fuel cut off switch poss bad or tripped did u get hit or someone bump ur car
Mar 28, 2010 | 1998 Mercury Sable
How do I change transmission fluid in a 1998 Sable?
ok there are 2 ways..
1 .) get a pump machine and pump it out (like the kind most mechanics use)
2.) the easy way
  • under the transmission is a bolt to the oil pan..
  • unbolt it,, the transmission oil will come out.. (this bolt is actually a flush plug)
  • when its all drained out tighten back the bolt and fill it with new fluid.. ( 5 - 6 quarts)
  • easy as that .. good luck
Mar 16, 2010 | 1998 Mercury Sable
Windshield washer will not operate , resevoir is full of solution 1992 mercury sable
The windshield wiper has a motor located in the hood.
This motor normally gets damaged within time and it might be repaired or replaced but wouldn't cost so much.
Take care.
Dec 14, 2009 | 1992 Mercury Sable
Need to know the fuse box diagram, what fuse pertains to the wipers... the wipers quit today and I do not have the manual. I opened the hood and see the fuses etc, but have no idea which one is for the...
fuse panel in car on driver side by left knee under dash
Visual Inspection Chart
Mechanical Electrical
  • Wiper linkage
  • Washer nozzles
  • Washer pump hoses
  • Central junction box (CJB) Fuse 211 (15A), Fuse 215 (30A)
  • Multifunction switch
  • Rear window wiper switch
  • Wiper run/park relay
  • Wiper high/low relay
  • Windshield wiper motor
  • Windshield washer pump
  • Rear window washer pump
  • Circuitry
  • Battery junction box (BJB)
  • CJB
  • Generic electronic module (GEM)
Dec 11, 2009 | 2003 Mercury Sable
Install Aftermarket Stereo in 1998 Mercury Sable
You need to buy a radio from Best Buy or somewhere. Installing on a Sable is not easy because your radio face plate is in the front but the tuner itself is located in the trunk and you need to run wires from the dash to the trunk. You need to buy a radio and $80 parts kit, but I promise it is not an easy install unless you are familiar with car audio and running wires through cars.
Dec 01, 2008 | Car Audio & Video
Open Questions:
I'm I dropped my necklace inside my 2018 Camry XSE & I finally saw it today a few weeks inside the lining of the drivers seat belt buckle. Can you tell me how to retrieve my necklace? Thanks! Denise My necklace is inside the lining around the "stem?" Of the seat belt buckle down inside a hole. It's a white gold necklace but appeared to me that it's laying on top of something silver? Possibly some type of track inside the assembly. Honestly I have no idea what I'm talking about. I was excited when I saw it since it appeared as though it could be easily retrieved and it doesn't look like it's very far down inside the lining of the buckle either, so since I have tiny hands I thought I might possibly even be able to get it out with only my hand. Sadly I was mistaken. Next I took some thick, heavy craft wire; first thing I thought of bent it over & made a hook on on end? I'm no fisherman but it seemed that logically it should work? I should be able to catch the chain in the hook. With the fabric of the lining being a charcoal color, inside the lining even darker. Inside a dark car with only an over head light, trying to hold a flashlight while necklace fishing in over 100 degree temps, though I'm stubborn and didn't want to. The heat did finally convince me I had no idea what I as doing and the chances of my catching my necklace at that point much less actually reeling it in safely were probably few and far between. So I'm back to searching the internet yet again. Ha! If you're wondering why I'm going to such lengths to retrieve a necklace, I bought it the day my first grand baby was born and it has her name and birth information engraved on it. It's the sentimental value for her DeDe that makes it so special and why I want to get it back so badly. I'm very much appreciative of anything you can advise me to do to help me with this process. Thank you so much, Denise Tallant a/k/a Stella James's DeDe
Sep 24, 2018 | Baby Gear
Baby Gear Logo
132 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
