Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
MAG Innovision LT916S monitor problem
I have a MAG Innovision LT916S monitor that has the following problem:
"Like others here I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. "
I copied the description above for someone else's complaint. Apparently this is a common problem.
Can this monitor be saved? It's only about 2 years old.
Rob
  • 2 more comments
  • Anonymous Mar 13, 2008
    I have a MAG Innovision 900w (prodduct no:LT1919WDb) monitor that has the following problem:
    "Like others here I start my COMPUTER
    then it goes black while leaving the power light blue I can only see
    another 1/4 second. "and if computer goes in to sleep you will see the no singal message.
  • Anonymous Feb 16, 2009
    So if the problem is because of the lamps, how does one get ahold of new ones and replace them?
  • thomasprice Feb 17, 2009
    I have a LT1919WDB 19" Wide Screen LCD Monitor and we did the flashlight trick like the solution said and we see icons. Now we need to know where to order the lightbulb(s) to replace.
  • bobcat1957 May 11, 2010
    Still can't find where to get the backlight. I clicked on several links but no joy. do you know the part number?
    Thanks in advance for your help!
    Cindy
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Posted on Mar 15, 2008
    Problem Solver:
  • 5 Answers
Yes, open it and put in two new 220uf 25v capacitors and it will work great. Opening it is the hardest part.
Posted on Sep 22, 2009
Should have clarified I have a Mag lcd LT916s and need a backlight bulb.
Thanks,
Cindy
Posted on May 20, 2009
Monitor goes blank then displays "mode not supported"
INstall the correct Video graphic card driver. The driver CD must have been shipped with the Monitor. Just put that CD in, and follow the on screen instructions.
Mar 27, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
LCD MAG Innovision LT916s blak out
Hi...there,
Are you sure you installed to the right side...There (-) side too you know! Also, testing the blue buttons alike caps too....
Jul 15, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor went Blank / Black (MAG Inov...lt916s)
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
How do you open a Mag Innovision LCD Monitor LT916s ?
There may be some interior support hooks that keep it together.  look for metal clips between the crease of the front and rear pieces.  Definitely use caution with opening as you do not want to force pressure against the screen.
Dec 21, 2007 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
1,592 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
