Question about Paradyne (6211-A2-200) Router
No Advanced setting
I recently aquired a few paradyne routers that are 6211-A1-200. I cannot configure them however because they don't have an "Easy Mode" nor an "Advanced" section when i log into them. I tried to hard code an IP addess and have used firefox and IE. Was unable to find a firmware update and cannot estabolish a PPPoE either. I have tried the reset button on the modem and have used the restore defaults once logged into it. Can anyone suggest anything to try to fix this?
  • Shadowfox7x Mar 07, 2008
    thanks for any advise you may be able to offer
Ok.... so i fixed my own issue...
All it needed was a Firmware Update.
No thanks to your site.. :P
Posted on Mar 13, 2008
I lost cd of router paradyne 6211 1 port so i can't use usb of this router,my operating system is win7 x64 i need the driver for this router
Best way is to go buy a CAT5 Ethernet cable and don't use the USB at all. You don't need driver to use that cable.
Jun 23, 2011 | Paradyne 6211 ADSL2+ Router (6211I1200)
Is there UPNP option to enabel it in paradyne routers? i cant find any related options when configuring the router
It seems that the Model doen't have a direct option to configure UPNP. However you can refer the following articles which might help you out
http://www.grc.com/unpnp/unpnp.htm
http://www.zhone.com/support/manuals/docs/62/6211-A2-ZB21-40.pdf
Please let me know whether the above articles helped you..
Thank you
Dec 06, 2010 | Paradyne 6211 ADSL2+ Router (6211I1200)
Unable to use admin username remotely
Most routers do not allow admin access from their WAN (public) side due to security concerns. Many routers allow you to enable this service from their browser-based configuration screens, but the 6211 does not. However, you can access advanced commands by logging into the router with telnet (from the LAN side) instead of a browser. The "remoteaccess" command allows you to turn on the feature you desire.
Full instructions for the command-line interface are here:6211-I1 ADSL2+ Router Command Line Interface User's Guide
You may need to upgrade your firmware to 3.00.22: Zhone/Paradyne Firmware - TSTT Forum
Dec 14, 2009 | Paradyne 6211 ADSL2+ Router (6211I1200)
What is the username and password for paradyne adsl2+ 6211-A3-304
The default username is Admin and the password is Admin. Both are case sensitive
Sep 01, 2009 | Paradyne (6211-A2-200) Router
HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Bridged Mode
Verify this with your ISP, but if you go into your modem settings, click on "Advanced Setup", click on WAN, when page opens, click "Edit". After clicking "Next", you come to the page labelled, "Connection Type". It is there you select what mode you'd like it to work in. When you are through selecting click NEXT till you get to the page with the SAVE button. Click Save and wait for page with FINISH to come up. Click FINISH and wait for the router to reboot(2 mins). Please write down the previous settings so you'll be able to undo whatever you do.
Mar 04, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
Network extender
You don't -- the strength of the transmitter inside the unit is what limits the signal-strength out at 300 meters.
Instead, you need a "repeater" -- some people have built their own, using a Linksys router, and then reprogramming it with the free 'DD-WRT' software, and configuring the device as a repeater, rather than as an Access Point.
Nov 08, 2007 | Paradyne (6211-A2-200) Router
Paradyne Dsl Modem
Hi, If I understand you right, what you want is to use your Paradyne 6211 modem to share the Internet connection to 2 PCs. One is connected through the USB and the second through Ethernet port. Tried it on a Siemens 4200 and a Prolink Hurricane 9000, both worked and can be done. To be sure, the IP settings of the PC connected via Ethernet was set to manual configuration. In your case try IP 192.168.1.3, Subnet Mask 255.255.255.0, Default Gateway 192.168.1.1, DNS Servers - whatever your ISP are using. You of course can try and see if it works in your modem. Hope this be of some help/idea. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 03, 2007 | Paradyne (6211-A2-200) Router
Paradyne (6211-A2-200) Router Logo
111 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
